Magnetic field due to an elliptical coil
The discussion revolves around finding the magnetic field produced by an elliptical coil, specifically in relation to the application of Biot-Savart's law. Participants are exploring whether a final expression exists for this scenario, similar to that of a circular loop.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the use of Biot-Savart's law for calculating the magnetic field and consider the complexity of the required integration. Questions arise regarding the existence of a simplified expression for the elliptical coil's magnetic field compared to a circular loop.
Some participants have provided guidance on using Biot-Savart's law and have encouraged sharing specific steps for further assistance. There is an acknowledgment of the tedious nature of the integration involved, and multiple interpretations of the problem are being explored.
One participant notes that their elliptical coil is positioned in the xy plane, with the magnetic field being sought in the yz plane, which may influence the approach taken. There is also mention of numerical integration capabilities using Matlab.
lekshmi
Is there any expression for finding out the magnetic field due to an elliptical coil?
Can we proceed with Biot Savart's law?
If so what is the final expression?
Yes you can use Biot Savart's Law.
So, now that you know "which instruments" to use, you can answer your second question yourself. If you need any help, just show us where you got stuck.
Good luck
regards
marlon
My elliptical coil lies in the xy plane.
I want to find out magnetic field in the yz plane. Zaxis is perpendicular to the coil.
I applied Biot Savart’s law and got integrals for B(y) and B(z).
Numerical integration is possible with Matlab.
But I would like to know whether there is any final expression as in the case of circular loop.
lekshmi
As marlon said, this is straight-forward application of Biot Savart's law and some very tedious integration. I'm not able to find the calculated result on the net.
Also, do you want to find the magnetic field at any point, or only in the xy plane?
If you want, you could post your steps here and we can help to check if it's right.
