| Thread Closed |
Genus, differential forms, and algebraic geometry |
Share Thread | Thread Tools |
| May24-06, 11:44 AM | #35 |
Recognitions:
try this on for size:
Math 8320 Spring 2004, Riemann’s view of plane curves Riemann’s idea was to classify all complex holomorphic functions of one variable. 1) Method: Consider a convergent power series as representing a holomorphic function in an open disc, and consider two power series as representing the same function if one is an analytic continuation of the other. 2) Problem: Two power series may be analytic continuations of each other and yet not determine the same function on the same open disc in the complex plane, so a family of such power series does not actually define a function. Solution: Construct the Riemann surface S on which they do give a well defined holomorphic function, by considering all pairs (U,f) where U is an open disc, f is a convergent power series in U, and f is an analytic continuation of some fixed power series f0. Then take the disjoint union of all the discs U, subject to the identification that on their overlaps the discs are identified if and only if the (overlap is non empty and the) functions they define agree there. Then S is a connected real 2 manifold, with a holomorphic structure and a holomorphic projection S-->C mapping S to the union (not disjoint union) of the discs U, and f is a well defined holomorphic function on S. 3) Enlarging the surface: If we include also points where f is meromorphic, and allow discs U which are open neighborhoods of the point at infinity on the complex line, then we get a holomorphic projection S-->P^1 = C union {p}, and f is also a holomorphic function S-->P^1. 4) This poses a new 2 part problem: (i) Classify all the holomorphic surfaces S. (ii) Given a surface S, classify all the meromorphic functions on S. 5) The fundamental example Given a polynomial F(z,w) of two complex variables, for each solution pair F(a,b) = 0, such that dF/dw (a,b) != 0, there is by the implicit function theorem, a neighborhood U of a, and a nbhd V of b, and a holomorphic function w = f(z) defined in U such that for all z in U, we have f(z) = w if and only if w is in V and F(z,w) = 0. I.e. we say F determines w = f(z) as an “implicit” function. If F is irreducible, then any two different implicit functions determined by F are analytic continuations of each other. For instance if F(z,w) = z-w^2, then there are for each a not 0, two holomorphic functions w(z) defined near a, the two square roots of z. In this example, the surface S determined by F is “essentially” equal to the closure of the plane curve X: {F(z,w) = 0}, in the projective plane P^2. More precisely, S is constructed by removing and then adding back a finite number of points to X as follows. Consider the open set of X where either dF/dw (a,b) != 0 or dF/dz (a,b) != 0. These are the non singular points of X. To these we wish to add some points in place of the singular points of X. I.e. the set of non singular points is a non compact manifold and we wish to compactify it. Consider an omitted i.e. a singular point p of X. These are always isolated, and projection of X onto an axis, either the z or w axis, is in the neighborhood of p, a finite covering space of the punctured disc U* centered at the z or w coordinate of p. All such connected covering spaces are of form t-->t^r for some r >= 1, and hence the domain of the covering map, which need not be connected, is a finite disjoint union of copies of U*. Then we can enlarge this space by simply adding in a separate center for each disc, making a larger 2 manifold. Doing this on an open cover of X in P^2, by copies of the plane C^2, we eventually get the surface S, which is in fact compact, and comes equipped with a holomorphic map S-->X in P^2, which is an isomorphism over the non singular points of X. S is thus a “desingularization” of X. For example if X crosses itself with two transverse branches at p, then S has two points lying over p, one for each branch or direction. If X has a cusp, or pinch point at p, but a punctured neighborhood of p is still connected, there is only one point of S over p, but it is not pinched. Theorem: (i) The Riemann surface S constructed above from an irreducible polynomial F is compact and connected, and conversely, any compact connected Riemann surface arises in this way. (ii) The field of meromorphic functions M(S) on S is isomorphic to the field of rational functions k(C) on the plane curve C, i.e. to the field generated by the rational functions z and w on C. I.e. this example precisely exhausts all the compact examples of Riemann surfaces. Corollary: The study of compact Riemann surfaces and meromorphic functions on them is equivalent to the study of algebraic plane curves and rational functions on them. 6) Analyzing the meromorphic function field M(S). If S is any compact R.S. then M(S) = C(f,g) is a finitely generated field extension of C of transcendence degree one, hence by the primitive element theorem, can be generated by two elements, and any two such elements define a holomorphic map S-->X in P^2 of degree one onto an irreducible plane algebraic curve, such that k(X) = M(S). Question: (i) Is it possible to embed S isomorphically onto an algebraic curve, either one in P^2 or in some larger space P^n? (ii) More generally, try to classify all holomorphic mappings S-->P^n and decide which ones are embeddings. Riemann’s intrinsic approach: Given a holomorphic map ƒ:S-->Pn, with homogeneous coordinates z0,...,zn on P^n, the fractions zi/z0 pull back to meromorphic functions ƒ1,...,ƒn on S, which are holomorphic on S0 = ƒ-1(z0 not 0), and these ƒi determine back the map ƒ. Indeed the ƒi determine the holomorphic map S0-->C^n = {z0 not 0}in P^n. Analyzing ƒ by the poles of the ƒi Note that since the ƒi are holomorphic in ƒ-1(z0 not 0), their poles are contained in the finite set ƒ-1(z0=0),and on that set the pole order cannot exceed the order of the zeroes of the function z0 at these points. I.e. the hyperplane divisor {z0 = 0}:H0 in P^n pulls back to a “divisor” <sum> njpj on S, and if ƒi = zi/z0 then the meromorphic function ƒi has divisor div(ƒi) = div(zi/z0) = div(zi) - div(z0) = ƒ*(Hi)-ƒ*(H0). Hence div(ƒi) + ƒ*(H0) = ƒ*(Hi) >= 0, and this is also true for every linear combination of these functions. I.e. the pole divisor of every ƒi is dominated by ƒ*(H0) = D0. Lets give a name to these functions whose pole divisor is dominated by D0. Definition: L(D0) = {f in M(S): f = 0 or div(f) +D0 >= 0}. Thus we see that a holomorphic map ƒ:S-->Pn is determined by a subspace of L(D0) where D0 = ƒ*(H0) is the divisor of the hyperplane section H0. Theorem(Riemann): For any divisor D on S, the space L(D) is finite dimensional over C. Moreover, if g = genus(S) as a topological surface, (i) deg(D) + 1 >= dimL(D) >= deg(D) +1 -g. (ii) If there is a positive divisor D with dimL(D) = deg(D)+1, then S = P^1. (iii) If deg(D) > 2g-2, then dimL(D) = deg(D)+1-g. Corollary of (i): If deg(D) >= g then dim(L(D)) >= 1, and deg(D)>=g+1 implies dimL(D) >= 2, hence, there always exists a holomorphic branched cover S-->P1 of degree <= g+1. Q: When does there exist such a cover of lower degree? Definition: S is called hyperelliptic if there is such a cover of degree 2, if and only if M(S) is a quadratic extension of C(z). Corollary of (iii): If deg(D) >= 2g+1, then L(D) defines an embedding S-->P^(d-g), in particular S always embeds in P^(g+1). In fact S always embeds in P^3. Question: Which S embed in P^2? Remark: The stronger Riemann Roch theorem implies that if K is the divisor of zeroes of a holomorphic differential on S, then L(K) defines an embedding in P^(g-1), the “canonical embedding”, if and only if S is not hyperelliptic. 7) Classifying projective mappings To classify all algebraic curves with Riemann surface S, we need to classify all holomorphic mappings S-->X in P^n to curves in projective space. We have asociated to each map ƒ:S-->P^n a divisor Do that determines ƒ, but the association is not a natural one, being an arbitrary choice of the hyperplane section by H0. We want to consider all hyperplane sections and ask what they have in common. If h: <sum>cjz^j is any linear polynomial defining a hyperplane H, then h/z0 is a rational function f with div(f) = ƒ*(H)-ƒ*(H0) = D-D0, so we say Definition: two divisors D,D0 on S are linearly equivalent and write D equiv D0, if and only if there is a meromorphic function f on S with D-D0 = div(f), iff D = div(f)+D0. In particular, D equiv D0 implies that L(D) isom. L(D0) via multiplication by f. and L(D) defines an embedding iff L(D0) does so. Indeed from the isomorphism taking g to fg, we see that a basis in one space corresponds to a basis of the other defining the same map to P^n, i.e. (ƒ0,...,ƒn) and (fƒ0,...,fƒn) define the same map. Thus to classify projective mappings of S, it suffices to classify divisors on S up to linear equivalence. Definition: Pic(S) = set of linear equivalence classes of divisors on S. Fact: The divisor of a meromorphic function on S has degree zero. Corollary: Pic(S) = <sum> Pic^d(S) where d is the degree of the divisors classes in Pic^d(S). Definition: Pic^0(S) = Jac(S) is called the Jacobian variety of S. Definition: S^(d) = (Sx..xS)/Symd = dth symmetric product of S = set of positive divisors of degree d on S. Then there is a natural map S^(d)-->Pic^d(S), taking a positive divisor D to its linear equivalence class O(D), called the Abel map. [Actually the notation O(D) usually denotes another equivalent notion the locally free rank one sheaf determined by D.] Remark: If L is a point of Picd(S) with d > 0, L = O(D) for some D>0 if and only if dimL(D) > 0. Proof: If D > 0, then C is contained in L(D). And if dimL(D)>0, then there is an f != 0 in L(D) hence D+div(f) >= 0, hence > 0.QED. Corollary: The map S^(g)-->Pic^g (S) is surjective. Proof: Riemann’s theorem showed that dimL(D)>0 if deg(D) >= g. QED. It can be shown that Pic^g hence every Pic^d can be given the structure of algebraic variety of dimension g. In fact. Theorem: (i) Pic^d(S) isom C^g/L, where L is a rank 2g lattice subgroup of Cg. (ii) The image of the map S^(g-1)-->Pic^(g-1)(S) is a subvariety “theta” of codimension one, i.e. dimension g-1, called the “theta divisor”. (iii) There is an embedding Pic^(g-1)-->P^N such that 3.theta is a hyperplane section divisor. (iv) If O(D) = L in Pic^(g-1)(S) is any point, then dimL(D) = multL(theta). (v) If g(S) >= 4, then g-3 >= dim(sing(theta)) >= g-4, and dim(sing(theta)) = g-3 iff S is hyperelliptic. (vi) If g(S) >= 5 and S is not hyperelliptic, then rank 4 double points are dense in sing(theta), and the intersection in P(T0Pic^(g-1)(S)) isom P^(g-1), of the quadric tangent cones to theta at all such points, equals the canonically embedded model of S. (vii) Given g,r,d >=0, every S of genus g has a divisor D of degree d with dimL(D) >= r+1 iff g-(r+1)(g-d+r) >= 0. Next we discuss how to clasify all Riemann surfaces of genus g, using the idea of a moduli space. (to be continued?) |
| May24-06, 01:42 PM | #36 |
Recognitions:
i made a mistake about the use of the word genus for higher dimensional varieties - usually the words geometric genus are used not for the number of 1 forms, but for the number of n forms, where n = dim of variety.
| May24-06, 02:02 PM | #37 |
Recognitions:
another rmark to hurkyl on genera of plane quartics. a plane quartic like y^2 = quartic in x, has arithmetic genus 3 but geometric genus 1.
i.e. this is a singular curve and there are two ways to associate a non singualr curve to it: one is to vary the equatioin a little, i.e. the coefficients, until the curve becomes non singular. the genus of that non singular curve is the arithmetic genus of the original curve. the other way is to "desingularize" the curve, by removing all singular points, creating 2 punctures, and then putting in a disc centered at each puncture. i.e. topologically i believe this curve looks like a modified curve of genus one, i.e. a torus but with two distinct points identified. Then one can do surgery in several ways on this curve. start by removing a small nbhd of the singular point, i.e. of the point resulting from gluing two points of the torus together. That leasves two disc shaped holes. then the simplest thing to do is glue in two discs, one in each hole, giving sa torus, of genus one. but one can also glue in any other manifold with boundary whose boundary consists of exactly two discs, such as a cylinder giuving a curve of genus 2, or a curve of genus one with two discs removed, giving a curve of genus three. this last is what happens when we simply vary the coefficients until the curve becomes a smooth quartic. one can see this dynamically, by varying the equation of a smooth quartic as follows: consider y^2 - ey^3 = x(x^3-1), and let e go to zero. as e goes to zero, the torus with two discs removed collapses into the singualr point. the lost homology cycles are called "vanishing cycles" and lefschetz studied them deeply in pencils of varying surfaces.. deligne used lefschetz pencils to prove the weil conjectures 30 years ago. |
| May24-06, 11:33 PM | #38 |
Recognitions:
here is my favorite way to calculate the genus of a plane cubic: note that a cubic degenerates to a triangle, anfd a triangle ahs one hole, so the genus is the number of holes namel;y one. for, a quartic note there are three holes in a triangle (with infinijtely long sides) plus one line.
what is the genus of a quntic? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Genus, differential forms, and algebraic geometry
| Subvarieties in algebraic geometry | Linear & Abstract Algebra | 8 | ||
| what is algebraic geometry | General Math | 37 | ||
| Algebraic Geometry | General Math | 3 | ||
| More algebraic geometry questions | Linear & Abstract Algebra | 43 | ||
