Why Can't I Rename Folders on My Desktop in Windows XP Pro?
  • Thread starter Thread starter ranger
    Desktop
The discussion revolves around a user experiencing difficulties renaming folders on their desktop in Windows XP Pro. The scope includes troubleshooting steps, user experiences, and potential solutions related to file management within the operating system.
  • One participant describes their inability to rename folders and asks for help, noting they are logged in as an admin.
  • Another participant seeks clarification on whether the rename option is missing from the right-click menu or from the properties menu, and asks when the issue began.
  • A different participant suggests that the rename option is not in properties but can be accessed via right-clicking, and proposes a method of clicking on the folder to prompt a rename.
  • One participant mentions trying the DOS command 'REN' as a potential solution if other methods fail.
  • Another participant notes that the rename option is missing when right-clicking and suspects that desktop permissions may be the issue, as renaming works when moving the folder elsewhere.
  • A participant inquires about the type of file being renamed, indicating a need for more context.
  • A response confirms the issue affects all file types and folders.
  • Another participant suggests using the F2 key after selecting the folder to rename it, while also reiterating the right-click method to access properties.
Participants express varying methods for renaming folders, with some suggesting different approaches and others indicating that certain methods do not work. There is no consensus on a definitive solution, and the discussion remains unresolved regarding the underlying cause of the issue.
Participants mention potential issues with permissions on the desktop, but the exact cause of the renaming problem is not determined. The effectiveness of suggested methods varies among participants.
ranger
I have a problem. I'm using Windows XP Pro and I can't seem to rename folders on my desktop or folders within folders on my desktop. There is no option to rename the folder in the properties. I am logged in as the admin. Any help?
--thank you.
Computer science news on Phys.org
--thank you.
Do you mean that when you right click there is no option to rename the folder or when you right click and then click on properties there is no option. Please elaborate. Also when did this start happening?
--thank you.
I don't quite remember how it was with Windows, but as far as I remember, there is no option 'rename' in properties. There is one when you do right click, below 'copy' and 'paste'. If there is no such, then try to do a single click on a file, and then after 5 seconds or so, do another click, and you should be prompted to input the new name for the file. Yet if this also doesn't work, check whether a command REN works (in DOS)
REN file file1
If none of these methods works, I'm pretty confused.
REN file file1
You can rename a folder in properties as well. Its the first text box under the "General" tab. The textbox is unlabeled though and just has the original name of the folder inside. But if you can't rename it using any of these methods, then...I don't know.
The rename option is missinig when I right click the folder/file. I tried the method where I click and wait a few seconds, but that does not work. I can rename if I move the folder to another part of my drive. It seems that the permissions for my desktop is messed up.
just the last question for a day, and that's it. What kind of file are you trying to rename?
It goes for all file types and folders.
OK, have you tried clicking once (left or normal mouse button) on the icon of the file / folder. The text should turn blue - now press your 'F2' key - the text should now be highlighted, and you can delete / overtype the text.
Also, the other posts should be correct, Right click on the icon of the file / folder in question, and go down the list to 'properties' and click that. Now you should have a set of tabs, with lots of useful *smirk* information - general has the name of the icon, which you should be able to read and change / overtype.
HTH
Jimble
  • · Replies 16 ·
  • · Replies 104 ·
  • · Replies 17 ·
  • · Replies 24 ·
11K
