| Thread Closed |
Energy required to raise temperature. |
Share Thread | Thread Tools |
| Jan8-04, 08:42 PM | #1 |
Is the amount of energy needed to raise the temperature of a substance linear or not? For instance, would it take the same amount of energy to raise a liter of water from 5 to 10 degrees celcius as it would to raise the same volume of water from 80 to 85 degrees celcius?
In fact, I don't even know if temperature is linear or not... |
| Jan8-04, 09:52 PM | #2 |
Heat capacities are NOT generally constant.
| Jan8-04, 09:59 PM | #3 |
As I recall from experiments in highschool physics, we heated a container of water over a Bunson Burner (which produces a fairly constant energy output)and the temperature increase was pretty linear, except during phase transitions.
| Jan9-04, 12:17 AM | #4 |
Mentor
Specific heat capacity info
Specific heat capacity is constant when not dealing with a phase change as Lurch implied. Temperature is kinetic energy - so to answer your question, I need to know in relation to what? In relation to kinetic energy, yes, of course, its linear. In relation to particle velocity, its parabolic. |
| Jan9-04, 01:09 AM | #5 |
The second law of thermodynamics demands that Cv does vary over large temperature changes so that it goes to zero as you approach 0 Kelvin. |
| Jan9-04, 02:47 AM | #6 |
Recognitions:
| Jan9-04, 03:07 AM | #7 |
What is this? Hollywood Squares? Everyone posts bulls**t answers off the tops of their heads? The kid asks a question and gets this kind of nonsense? Check your handbooks, gang. Cx[ is NOT, has NEVER been, and NEVER will be a constant for any substance. mmwave is correct in that the variation is of the order of tenths of a percent to a percent over thirty to hundred K ranges, excluding a major temperature dependence from 0 K to what, call it 100 K for this discussion. Further, the change in Cx isn't even monotonic; that is, (dC/dT) can be positive, zero, or negative; technically, one could call C a constant at local maxima or minima, but that's begging the point.
HEAT CAPACITY IS NOT CONSTANT. |
| Jan9-04, 05:29 AM | #8 |
Bystander is correct: heat capacity is not a constant, over varying temperatures. It does not, however, change very much for most common substances over most common temperature changes so that temperature change is approximately constant over a small range of temperature change.
It is much the same situation as with "Hooke's Law": the force a stretched spring exerts is not generally a linear function of amount of stretch but any (differentiable) function can be approximated by its linear (tangent) approximation over a small range. |
| Jan9-04, 12:31 PM | #9 |
Mentor
Even in undegraduate level chemistry, thermodynamics, and heat transfer classes, its considered/assumed to be constant. For this reason, its much better to call it constant and leave it at that than call it not constant and leave it at that. If you're going to say its not constant, you need to qualify the statement by saying the variability is so small it can be ignored for all but the most extreme cases. In fact, I've tried to find the actual variation for water from Google and come up empty. Every site I checked just said 1.0cal at stp (by definition). So anyone know what it is at 100C? |
| Jan9-04, 01:21 PM | #10 |
Yes at undergraduate level u can assume it to be constant unless & until A relation of C with T is specified
| Jan9-04, 02:08 PM | #11 |
One thousand one --- one thousand two --- one thousand three --- one thousand four ---
| Jan9-04, 04:31 PM | #12 |
Recognitions:
On the 0.001% chance that wasteofo2 needs such details, here they are. Specific heat from 5C to 10C is on average 1.0040 cal/gm/deg.C. Specific heat from 80C to 85C is on average 1.0038 cal/gm/deg.C. So in answer to wasteofo2's question The specific heat is 1.0094 at 0C, goes through a minimum of 0.9982 at 37.5C, and is back up to 1.0074 at 100C. |
| Jan9-04, 06:44 PM | #13 |
Well, hell --- I ain't even gonna count to ten this time --- "gotcha" is if I deliberately trick you into falling on your face --- I posted the correct response --- it's up to wo2 to holler for details if he wants 'em --- you butt in with an "incorrection" --- you don't know what you're talking about, don't post.
F'rinstance, density of water is 3-3.5% less at 80-85 C than at 5-10 C, and the mass of one "liter" is then less by 3-3.5% --- OK, you made the same mistake anyone is going to make within this context --- TWICE? That's "GOTCHA." I'll repeat, "Heat capacities are NOT generally constant." Calling heat capacity of water "one calorie per K," without specifying whether it's "mean, defined, 15 C, 20 C," is good enough for govt. work, farm machinery, physicists, and engineers, but IT AIN'T good enough to do decent thermo." And it's a damned fool who assumes that heat capacities of other substances are constant. |
| Jan10-04, 02:38 AM | #14 |
For those who are interested in heat capacity/specific heat, its temperature dependence, and the utility of an awareness of such, http://www.madsci.org/posts/archives...9142.Ch.r.html .
| Thread Closed |
| Thread Tools | |
Similar Threads for: Energy required to raise temperature.
| Bearing temperature raise | Mechanical Engineering | 2 | ||
| [SOLVED] Grams and volume of steam needed to raise the temperature of expresso | Introductory Physics Homework | 0 | ||
| Required Energy | Introductory Physics Homework | 1 | ||
| Calculate time to raise temperature of water | Introductory Physics Homework | 7 | ||
| Why do nuclear power plants raise the temperature of sea water? | Introductory Physics Homework | 5 | ||
