I'm confused about proving vector spaces
The discussion revolves around proving that the set of all differentiable real-valued functions defined on the real line forms a vector space. Participants are tasked with verifying the eight axioms of vector spaces, particularly focusing on the operations of addition and scalar multiplication defined for functions.
  • Participants discuss the necessity of proving specific axioms, such as the commutativity of addition. Some express confusion about the foundational aspects of the proof process and the assumptions that can be made regarding real numbers.
There is an ongoing exploration of different methods to prove the properties of vector spaces. Some participants suggest using established properties of real numbers, while others question the validity of assuming these properties without proof. Guidance has been offered regarding how to approach the proof of commutativity, and there is a recognition of the importance of understanding the definitions involved.
Participants are navigating the complexities of formal mathematical proofs and the assumptions that can be made in the context of vector spaces. There is mention of alternative definitions and concepts, such as linear manifolds and affine spaces, which may contribute to the confusion surrounding terminology.
astral
Let V denote the set of all differentiable real-valued functions defined on the real line. Prove that V is a vector space with the operations of addition and scalar multiplication as follows:
(f + g)(s) = f(s) + g(s) and (cf)(s) = c[f(s)]
I know I have to prove this by checking the 8 axioms of vector spaces, but I'm very confused as to how I actually go about it in a formal mathematical proof. If someone could just prove one of them (say commutativity of addition a+b=b+a), I'm sure I'll be able to figure out the rest.
I'm just confused about proving something so fundamental. I keep thinking there are no operations I can perform without first proving what I'm trying to prove. GAH
f(s) and g(s) are just numbers. You should invoke the comutivity and associativity of operations on real numbers, along with the definition you were given.
I'm sorry if the answer is really obvious, but could you give me an example anyway?
Thanks.
For instance, you want to show that (f+g)(s) = (g+f)(s). By the definition, (f+g)(s) = f(s) + g(s), and (g+f)(s) = g(s) + f(s). But f(s) and g(s) are just numbers, so (assuming the standard properties of real numbers) g(s) + f(s) = f(s) + g(s). From which the desired result obtains.
I thought of doing it this way, which seems a bit better:
(g + f)(s) = g(s) + f(s)
(f + g)(s) + f(s) = ( f(s) + g(s) ) + f(s) [by the definition]
(f + g)(s) + f(s) = f(s) + ( g(s) + f(s) ) [by the associativity axiom]
(f + g)(s) + f(s) = f(s) + (g + f)(s) (by the definition)
So simple. Thanks for your help.
You make it more complicated than it is. Adding another f(s) as you have done is completely unneccessary. Commutativity in the function space follws directly from the commutativity of the real numbers under addition. Nothing else is needed.
hmmmm.
It just seems to me like your method is simply proving commutativity by assuming commutativity, which intrinsically doesn't prove anything.
maybe I just don't understand.
I'm telling you to assume cummutativity of the real numbers under addition, which is not what you are trying to prove. You are trying to prove commutativity of a functionspace under an "addition" rule defined by (f+g)(s)=f(s)+g(s). That is something completely different from real numbers being commutative under addition. Although, it is the case that this particular addition rule, together with the standard properties of real numbers, make it almost trivial to prove.
Assuming the standard properties of real numbers seems completely reasonable (to me) for a problem like this; of course you're always welcome to assume less. You could start from the Peano axioms if you really want to. . .
Thanks for your patience, and I am definitely getting a better understanding of this now. I'm just new to vector spaces, and I just want to be sure I know what I can assume when dealing with these problems.
I think I'll completely understand if you show me how you would prove that an addition definition such as (f+g)(s)=f(s)+2g(s) is or is not commutative using the same method you used for proving the trivial definition (f+g)(s)=f(s)+g(s)
Sure, no problem, first here's the original problem, in morbid detail, just to be clear:
[tex] \begin{align*}<br /> (f+g)(s) &= f(s) + g(s) \quad \text{definition of addition of \textbf{functions}} \\<br /> & = g(s) + f(s) \quad \text{addition of \textbf{numbers} is commutative} \\<br /> & = (g+f)(s) \quad \text{definition of addition of \textbf{functions}} <br /> \end{align*}[/tex]
As for proving something something is not commutative, it is usually just easiest to provide a counterexample. Let [tex]f(s) = s[/tex], and [tex]g(s) = s^2[/tex]. Then by your new rule, when, say, s = 2, we have
[tex](f+g)(2) = 2 + 2\cdot2^2 =10 \neq 8 = 2^2 + 2\cdot 2 = (g+f)(2)[/tex]
Therefore, since [tex](f+g)(s) \neq (g+f)(s)[/tex] in general, addition under this rule is not commutative.
As an aside, so that you don't get so bogged down in the details of proving vector space properties that you lose track of the essence of what vector spaces are about, let me make one remark. Vector spaces are places where objects combine linearly to give new objects that are also vectors. That is, if [tex]A[/tex] and [tex]B[/tex] are vectors in some vector space [tex]V[/tex], and [tex]\alpha[/tex] and [tex]\beta[/tex] are (real or complex) scalars, then [tex]\alpha A + \beta B[/tex] is also a vector in [tex]V[/tex]. Vector spaces are "closed" under taking linear combinations (so they are also sometimes called "linear spaces"), and this is their most important property.
In this specific case, the important kernel of information is that if you add differentiable functions together pointwise, or multiply them by real numbers, you still get another differentiable function.
Excellent. Thank you very much for your help.
A linear space is not the same as a vector space. I'd avoid using that particular label for them.There is at least one definition of a linear space that is commonly used that would cause confusion. ( I mean the goemeter's one)
MathWorld disagrees, and so does http://wombat.doc.ic.ac.uk/foldoc/foldoc.cgi?linear+space , and every other reference I could turn up. So do I. I've never once encountered any context where "linear space" and "vector space" were not complete synonyms.
I'm certainly willing to have my opinion informed by hearing about a linear space that is not a vector space, though.
I'm wondering if Matt Grime wasn't referring to a "linear manifold" (In, say, R3, all subspaces are planes or lines that contain the origin. A linear manifold would be a plane or line that does not necessarily contain the origin.
Another possibility is the "affine space": R1, R2, Rn can be taken as examples of affine spaces in which we have points rather than vectors. We do not, in general, define addition or scalar multiplication of points. Given any affine space, we can turn it into a vector space by choosing a particular coordinate system.
I, however, am with BigRedDot. I would not call either a linear manifold or an affine space a "linear space". I would identify "linear space" with "vector space".
Matt, the ball's in your court!
  • · Replies 0 ·
9K
  • · Replies 42 ·
  • · Replies 18 ·
