Solving Vector Questions: Find Relationship, Point C & Value of k
  • Thread starter Thread starter masterofthewave124
    Vector
The discussion revolves around three distinct problems involving vector relationships, geometry of rectangles, and systems of equations. The first problem concerns the intersection of two lines defined by their parametric equations, where participants explore the conditions under which they intersect. The second problem involves finding a constant in the context of a rectangle formed by points defined by position vectors. The third problem addresses the values of a parameter in a system of linear equations that determine the nature of its solutions.
  • Mixed
  • Participants discuss the conditions for the intersection of lines, questioning the relationship between direction vectors. They also explore the implications of perpendicularity in the context of a rectangle. In the system of equations, there are inquiries about the use of matrix methods and the significance of specific values of the parameter k.
Some participants have provided insights into the conditions for line intersection and the geometric properties of rectangles. There is ongoing exploration of the implications of different values of k in the system of equations, with some participants expressing confusion about the outcomes associated with these values.
Participants note the challenges posed by multiple unknowns in the equations and the need for specific values to progress through the problems. There is also mention of the potential for skew lines in three-dimensional space, which adds complexity to the discussion of line intersections.
masterofthewave124
1. Consider two lines L1: r = (2,0,0) + t(1,2,−1) and L2: r =(3,2,3) + s(p,q,1)
Find a relationship between p and q [independent of s and t] that ensures that L1 and L2 intersect.
i proceeded like any other interesection of line question but got stuck when i got single equations with 3 unknowns (including p and q)
2. The position vectors of the points A and B, with respect to the origin O, are 2i−3j+3k and 5i + j+ck respectively, where c is a constant. The point C is such that OABC is a rectangle.
(a) Find the value of c
(b) Find the point C
how do i find c? if i had the exact coordinates of B, I am pretty sure developing an equation like OA = CB would give be the point C (which is part b))
3. In the following system of equations, k is a real number.
x−2y+z=4
x−y−z=3
x+y+kz=1
(a) Determine the value(s) of k for which the system of equations has
(i) exactly one solution
(ii) infinitely many solutions
should i solve this using a standard matrix? what happens when i get down to x = something, y = something, z = something/k. i don't know really what to do differently for i) and ii), what would each part entail?
i know i haven't shown a tremendous amount of work but I'm not the greatest thinker and i really have a deficiency of knowledge in this area. thanks for any help given!
1. for this one, note that 2 lines will intersect iff their direction vectors are not parallel, i.e. not scalar multiples of each other. so do you know of a condition you can put on (p,q,1) such that it is not a multiple of (1,2,-1)?
3. when you put it into matrix form and reduce it, which values of k will give you a row of zeros? for those values, there will be infinitely many solutions. if there are no rows of zeros there will be one solution.
hmm ill start working with what you said, thanks by the way. any further advice is welcome too!
i also have a question about the distance between two skew lines. geometrically, what is the relationship between the line that represents the distance and the skew lines. the distance line is perpendicular to both no?
For Q2, use the fact that adjacent sides of a rectangle are perpendicular to each other.
No, that's not true. In 3 dimensions two lines may be "skew", neither parallel nor intersecting. A simple example is the x axis, r= t(1, 0, 0) and the line r= (1, 1, 0)+ t(0, 0, 1), through (1, 1, 0) parallel to the z-axis.
masterofthewave124, you started correctly. in order for the lines, r = (2,0,0) + t(1,2,−1) and L2: r =(3,2,3) + s(p,q,1) to intesect, you must have x= 2+ t= 3+ ps, y= 2t= 2+ qs, z= -t= 3+ s for some t and s. Multiply the last, z, equation by 2 and add to the second, y, equation to eliminate t: 0= 8+ (2+ q)s so s= -8/(2+q). Now use the second equation to determine t: -t= 3+ s= 3- 8/(2+q)= (3q- 2)/(2+ q) so t= (2- 3q)/(2+ q). Finally, those two values must satisfy the first, x, equation:
2+ t= 3+ ps or 2+ (2-3q)/(2+q)= 3- 8p/(2+q).
(6- q)/(2+q)= (6+ 3q- 8p)/(2+q). In order for that to be true, and the two lines intersect, we must have 6- q= 6+3q- 8p or q= 2p (and, of course, q not equal to -2).
As pizzasky said, to be a rectangle, two sides, here the vectors 2i- 3j+ 3k and 5i+ j+ ck, must be perpendicular. Set the dot product of those vectors equal to 0 and solve for c.
I'm not sure why you say "if i had the exact coordinates of B"- you do. Being told that the "position vector of B, with respect ot the origin O, is 5i+ j+ ck" tells you that the "exact coordinates" of B are (5, 1, c) and you just found c.
x−2y+z=4
x−y−z=3
x+y+kz=1
If you are familiar with matrix methods, sure, go ahead and row-reduce the augmented matrix. For what value of k is the last row (excluding the "augmented part") not 0? What does that tell you? For what value of k are all the terms of the last row, (including the "augmented part") equal to 0? What does that tell you? There is, of course, a possible (iii) NO solution. For what value of k does that happen?
You don't have to use matrix methods of course. I you use you old algebraic methods to solve for x, y, and z, you will eventually have to divide by something involving k. For what values of k is that non-zero so you can solve the equation? For what values of k does that give a fraction in which both numerator and denominator are 0 (and what does that mean)? For what values of k (if any) does that give a fraction in which the numerator is non-zero but the denominator is zero?
what i meant about the exact coordinates of B is i don't have c. i was suggesting that you needed the answer from a) to do part b).
i have a question about your method, being that the rectangle OABC is formed by taking the vertices in order, shouldn't the dot product of A and C be 0 and not A and B? simply because isn't B a diagonal of the rectangle?
ok, i tried this method and i need some help here:
so x-2y+z = 4 (1)
x-y-z = 3 (2)
x+y+kz = 1 (3)
(1) - (2) = -y + 2z = 1 (4)
(1) - (3) = -3y + z(1-k) = 3 (5)
Then
3x(4) - (5) = 6z - z(1-k) = 0
z(5+k) = 0
it appears that for any value k, z will be zero. if k is -5, z would = 0/0? does that mean for any value k that's not -5, the lines intersect at a point and when k is -5, they intersect at a line?
evidently, i still don't understand the implications of the values of k. (i.e. k is nonzero, the numerator and denominator are zero, the denominator is zero). this is all so confusing.
Okay, you reduced it to z(5+k)= 0. No, it is not the case that "for any value k, z will be zero"- if k= -5, the equation reduces to 0*z= 0 and z can be anything. You have now answered your question: If z is any number except, -5, z= 0. Putting that into the previous equations
12x- 5= 0 so x= 5/12, and y= -1. That's a single solution. If k= -5, then z can be anything so there are an infinite number of solutions.
"does that mean for any value k that's not -5, the lines intersect at a point and when k is -5, they intersect at a line?"
Yes, that's exactly what it means!
My experience is, that when a single problem has "part a" and "part b", that's often the case!:rolleyes:
Oh, I see your point. I misread the problem. I assumed that OA and OB were two adjacent sides of the rectangle but since it specifically says "2. The position vectors of the points A and B, with respect to the origin O, are 2i−3j+3k and 5i + j+ck respectively, where c is a constant. The point C is such that OABC is a rectangle." It clearly intends that the A and B be adjacent so that OB is a diagonal, not a side of the rectangle.
(Notice that A, B, C, O are points, not vectors. It's better to say that OB is a diagonal rather than "B is a diagonal".)
Of course, OA+ OC= OB so OC= OB- OA= 5i + j+ck - (2i−3j+3k)= 3i+ 4j+ (c-3)k. Put in the value of c you got in (a) and take the dot product of OA and OC to see if those vectors are pependicular.
But at this point, we still haven't determined the value of c!
edit: nvm, your wording was just a bit confusing. thanks for all your help though!
for part b), should i just sub in the value for c and solve for OC using OB - OA?
has anyone given any consideration to the question: "geometrically, what is the relationship between the line that represents the distance and the skew lines. the distance line is perpendicular to both no?"
