Clocks and Time Dilation in Relativity
  • Context: Graduate
  • Thread starter Thread starter MonstersFromTheId
    Confusion Frame Ir
The discussion revolves around the concept of time dilation in relativity, particularly focusing on how clocks behave in different reference frames and under varying gravitational influences. Participants explore thought experiments and theoretical implications of time measurement without external references.
  • One participant questions how a clock "knows" to slow down when it enters a gravitational well, suggesting a thought experiment involving a box in free fall.
  • Another participant argues that the clock itself does not slow down; rather, the time dimension changes, and the clock continues to tick at a constant rate relative to itself.
  • A different viewpoint emphasizes that all clocks tick at the rate of 1 second per second, and any perceived slowing is relative to another clock, which is not available in the thought experiment.
  • One participant references Einstein's original description of clock synchronization and motion, discussing the implications of a clock at the equator running slower than one at the North Pole, while questioning whether this is due to actual time loss or spatial contraction during motion.
Participants express differing views on the nature of time dilation and the behavior of clocks in motion or under gravitational influence. There is no consensus on whether clocks actually slow down or if the perception of time is altered due to relative motion or gravitational effects.
Participants highlight the lack of a reference clock in the thought experiment, which complicates the ability to measure or compare time accurately. There are also unresolved assumptions regarding the nature of time and the effects of gravity on time measurement.
MonstersFromTheId
How does the "clock" know when to slow down?
Screwy question, I know, but the following thought experiment might help to make clear what I'm asking.
You and a clock are in a box. You can't see outside the box. You have no external references.
Inside the box you appear to be in free fall, i.e. no forces acting on you that you can detect.
From a God's eye point of view you and your little box are speeding through an empty part of space at constant speed, and your clock is ticking away at a constant rate. (Not that you can tell that from inside the box, but that's what's going on).
Unbeknownst to you as you sit in your little box (possibly watching old Seinfeld re-runs, or making a sandwich), your little box begins to pass within range of a steep gravity well.
So now your box starts to fall toward the gravity well. As it does, you start to pick up speed, and as you pick up speed your clock begins to tick more slowly (not that you can tell, since time is slowing for you as well). But the pertinent fact of the matter is that you clock IS starting to tick more slowly. Just because you can't tell it's ticking more slowly doesn't change the fact that it is.
So if there's no such thing as an absolute reference frame, how does your clock know enough to start ticking more slowly?
Your problem is that you are thinking of the clock as slowing down. Its not. The time dimension itself has changed. The clocks hand still moves one space every second, but the difference is that one second takes longer COMPARED TO another reference frame. The act of "slowing down" requires no knowledge of anything on the clocks part. It is still doing the same job, counting out seconds. The difference is that time itself is different compared to another reference frame.
All clocks tick at the rate of 1 second / second. When we say a clock slows down, we mean that when we compare the rate of that clock to some reference clock, we observe that our clock ticks slower than the reference clock.
It is usually but not always implied that there is some signal path of known and fixed time delay present between our clocks and the reference clock in order to make the comparison.
In this example, there is no reference clock, hence there is no way for any experiment to deterimine that the clock in the box is ticking more slowly (as long as the box is small).
If you watch the clock, for instance, it will appear to be ticking normally to you, for your time will be the same as the clocks time.
Einstein caused some uncertainty as to what takes place in his original description of what happens to clocks when they are put in motion - he describes the situation where two separated clocks are synchronized and then one is put in motion and when it reaches the other clock it will be out of sync (it will read less). He then goes on to further embellish upon what he calls a "peculiar result" by stating that a clock at the equator will run slower than one at the North pole (this presumes they are both at the same gravitational potential - which is not the case). But the interesting aspect of this assertion is whether the equitorial clock (the one moving about about 1000 mph relative to the clock at the North Pole) is actually running slower, or whether the moving clock simply accumulates less time during a revolution because it travels an effective contracted spatial distance - both analysis lead to the same result - an actual loss of time between the equitorial clock and the Pole clock as measured by the time of each revolution - but most authors reject the notion that one second per second in one frame is different that one second per second in another frame.
  • · Replies 54 ·
  • · Replies 115 ·
10K
  • · Replies 70 ·
  • · Replies 88 ·
