Understanding the Derivative of a Dot Product: A Question on the Product Rule
The discussion revolves around the derivative of a dot product and its relation to the product rule in calculus. Participants explore the implications of treating dot products of vector functions versus constant vectors, and the nature of scalars in this context. The conversation includes technical explanations and personal experiences with confusion surrounding the topic.
  • One participant expresses confusion about the derivative of a dot product, questioning how it relates to the product rule since a dot product yields a scalar, which they associate with having a derivative of zero.
  • Another participant clarifies that a "scalar" can refer to a "scalar function," which is not necessarily constant, thus differentiating between constant scalars and variable functions.
  • A third participant provides an example of vector functions, illustrating that the dot product of such functions is not constant and can vary, which is where the derivative formula becomes relevant.
  • One participant discusses the nature of derivatives as continuous linear maps and explains the bilinear map's derivative, emphasizing the linear approximation aspect.
  • A later reply shares a personal anecdote about confusion surrounding the derivative of bilinear maps, highlighting that even professionals can struggle with these concepts.
Participants do not reach a consensus; there are multiple competing views regarding the interpretation of derivatives in the context of dot products and bilinear maps. Some express confusion while others attempt to clarify the concepts.
Limitations include varying definitions of scalars and derivatives, as well as the potential for misunderstanding the linearity in different contexts. The discussion reflects a range of assumptions and interpretations that remain unresolved.
Gott_ist_tot
I have come across something that seems a little strange to me. The derivative of a dot product is something similar to the product rule. I am having difficulties grasping this. Isn't the dot product of two vectors a scalar? And then I always thought of a scalar as a real number and the derivative of a real number is 0. So why does a theorem similar to the product rule exist and work?
A "scalar" is generally a "scalar function"... which is not necessarily a "scalar constant". The derivative of a constant is what is zero.
Of two constant vectors, yes, the dot product is a constant (and a scalar). But when you consider vector functions, e.g.
T(x)=exp(x)i + log(x)j
U(x)=cos(x)i + csc(x)j
Then the dot-product of these will definitely not be a constant -- it will be the quantity exp(x)cos(x) + log(x)csc(x). That's where the formula is useful. You'll find that if T and U are constant vectors, then the formula will give you the expected result: 0.
product rule
it helps to know what a derivative is, i.e. that a derivative is a continuous linear map that approximates the difference in the values of the original map.
Take the multiplication map RxR-->R taking (x,y)-->xy. This is a bilinear map and its derivative at (a,b) is a linear map L(s,t) such that if x = a+s, y = b+t, then the difference xy-ab is approximated by the linear map L(s,t) to within an error which vanishes faster than (s,t) as (x,y) approaches (a,b).
In this case take L(s,t) = at+bs. Then the difference xy-ab differs from at+bs by the error term xy-ab - at-bs = (a+s)(b+t)-ab-at-bs = st, which does vanish faster than either s or t as (s,t) goes to zero.
so the derivative of xy, at (a,b), as a linear map on RxR, is the map taking (s,t) to at+bs. To get the leibniz rule, compose the derivative (f'(c),g'(c)) of a differentiable map R->RxR defined by a pair (f,g), with the derivative of multiplication taken at (f(c),g(c)).
This gives the linear map taking r to (f'(c)g(c)+f(c)g'(c))r.
as usually taught in elemenmtary calculus, this linear map is referred to only by the unique entry in tis 1by1 matrix, namely the number f'(c)g(c)+f(c)g'(c).
The same proof works for any continuous bilinear map, modulo the fact that commutativity does not always hold.
So the derivative of a possibly non commutative continuous bilinear map VxW-->U at a point (a,b), where V,W,U are complete normed vector spaces, maps (s,t) to (bs+at). and so the derivative of a product map fg:X-->U, viewed as a composite X-->VxV-->U where VxV-->U is a bilinear product, and (f,g) define the map X-->VxV, at the point c in X, is the linear map X-->U taking x in X to, what else? some plausible continuous linear function of x with values in U, namely [I guess] f’(c)(x).g(c) + f(c).g’(c)(x).
Hows that look?
:smile:
if this seems confusing, it is. i not long ago had an anonymous referee for a research paper of mine, object to a statement i made about the derivative of a bilinear map, which statement however was completely correct. so even professionals are confused by these things at times.
but this is a lesson in elarning the right definition of a derivative, as a linear approximation to the difference map f(x)-f(a), linear in (x-a) that is.
i also had a professional analyst friend make a mistake on this latter score in a prelim exam, confusing linearity in x with linearity in (x-a).
  • · Replies 20 ·
  • · Replies 23 ·
