| Thread Closed |
Block slides 4ft down a smooth plane & then slides on a rough surface (0.6) - s = ? |
Share Thread | Thread Tools |
| Jun21-06, 05:01 AM | #1 |
The 30 lb box A is released from rest and slides down along the smooth ramp and onto the surface. Determine the distance s from the end of the surface to where the box stops. The coefficient of kinetic friction between the cart and the box is [itex]\mu_k\,=\,0.6[/itex].
![]() Here is what I have so far: [tex]-W\,\Delta\,y\,=\,(-30\,lb)\,(-4\,ft)\,=\,120\,ft\,lb[/tex] [tex]\sum\,F_y\,=\,N\,-\,W\,=\,0\,\Rightarrow\,N\,=\,W\,=\,30\,lb[/tex] [tex]\sum\,F_x\,=\,-f_k\,=\,m\,a_x\,\Rightarrow\,-\mu_k\,N\,=\,m\,a_x[/tex] [tex](-0.6)\,(30\,lb)\,=\,(0.932)\,a_x[/tex] [tex]a_x\,=\,\frac{-18.6}{0.932}\,=\,-19.3\,\frac{ft}{s^2}[/tex] Now what? I know I need to find [itex]v_f[/itex] and the bottom of the hill and I am probably supposed to use a work-energy equation? [tex]\sum\,T_1\,+\,\sum\,U_{1\,-\,2}\,=\,\sum\,T_2[/tex] Please help, thanks. |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Jun21-06, 05:34 AM | #2 |
| Jun21-06, 06:32 AM | #3 |
Using that, I get this:
[tex]V_f^2\,=\,2\,g\,h\,=\,2\,(32.2)\,(4)\,=\,257.6[/tex] [tex]V_f\,=\,\sqrt{257.6}\,=\,16.05\,\frac{ft}{s}[/tex] [tex]v\,=\,v_0\,+\,a\,t[/tex] [tex]0\,=\,16.05\,+(-19.3)\,t[/tex] [tex]t\,=\,0.832\,s[/tex] [tex]s\,=\,s_0\,+\,v_0\,t\,+\,\frac{1}{2}\,a\,t^2[/tex] [tex]s\,=\,0\,+\,(16.05)\,(0.832)\,+\,\frac{1}{2}\,a\,t^2[/tex] [tex]s\,=\,6.67\,ft[/tex] The real answer is 3.33 ft though! What did I do wrong? |
| Jun21-06, 06:47 AM | #4 |
Your going to kick yourself for this one. You have calculated the distance travelled, not the distance from the end of the platform. HINT: What does 10 - 6.67 equal?
| Thread Closed |
| Thread Tools | |
Similar Threads for: Block slides 4ft down a smooth plane & then slides on a rough surface (0.6) - s = ?
| rough horizontal surface and an inclined smooth plane | Classical Physics | 7 | ||
| Particle slides down sphere | Introductory Physics Homework | 1 | ||
| Particle slides into a rod and pivots | Introductory Physics Homework | 5 | ||
| Slides with LaTEX | General Physics | 0 | ||
| block slides inclined plane | Introductory Physics Homework | 10 | ||
