Calculating a correction factor
  • Context: Graduate
  • Thread starter Thread starter laminatedevildoll
    Correction
The discussion revolves around calibrating a tilt meter sensor connected to a voltmeter and power supply. Participants explore how to adjust the circuit to achieve a zero voltage reading when placed on a leveled surface, using a calibration curve fit equation to derive necessary angles and correction factors.
  • Experimental/applied
  • One participant describes the calibration process and the need to adjust the circuit's sides based on voltage readings when the circuit is leveled.
  • Another participant questions the use of "arc degrees" as units for voltage and asks for clarification on the device being calibrated.
  • A later reply clarifies that the angles calculated from the calibration equation are indeed the angles of tilt, not voltage.
  • One participant suggests manually tilting the sensor to achieve a zero voltage reading and measuring that angle for calibration purposes.
  • Another participant proposes using trigonometry to calculate the required height adjustments for each side of the circuit based on the angles derived from the calibration curve.
Participants express varying levels of understanding regarding the calibration process and the specifics of the device. There is no consensus on the best method to achieve the desired calibration, with multiple approaches being discussed.
Some assumptions about the setup and the specific requirements for the calibration process remain unclear, and there are unresolved details regarding the application of trigonometric functions in this context.
laminatedevildoll
I am trying to calibrate this circuit, and it is hooked up to a voltmeter and also a power supply. When the circuit is horizontal, the voltmeter is supposed to read zero both in the x and y direction. Here, the x-direction is determined by tilting the circuit up and down and the y-direction is determined by tilting the circuit left and right (or something like that). Anyway, when I put the circuit on the leveled surface however, the voltmeter doesn't read zero for both x and y values. Therefore, in order for the voltage reading to read zero, I have sort of adjust the length of the four sides of the circuit so that the voltage is zero when it is on a leveled surface.
The circuit came with a calibration curve fit equation
theta = a + bV +cV**2+dV**3+eV**4+fV**5
where V is the X or Y output
and a,b,c,d,e,f is given for both the x-axis and the y-axis.
I calculated the angles using the voltage values I found when the circuit was leveled on the surface.
The voltage when the circuit is horizontal is 0.1999 arc degrees for the x-axis and -1.023 arc degrees for the y-axis. Using these values, I have to determine a correction factor for the four sides of the circuit, so I can make four stands to make the voltage zero when it's on a leveled surface. I'd appreciate if someone could give me some input on how I should do this. I know I have to use the angles I calculated somehow.
Mathematics news on Phys.org
Woof. What in the world are you talking about devildoll? Voltage does not have units of arc-degrees for starters. What is the device you are trying to calibrate? It sounds like it is some kind of tilt meter sensor?
Oops sorry. I meant the calculated theta (angle) from the equation above equals 0.1999 arc degrees for the x-axis and -1.023 arc degrees for y-axis. The measured voltages were 0.026 V for the x-axis and the -0.243 V for y-axis. I suppose the the value for the x-axis is close to zero, but the value for the y-axis is way off. So, I have to build four little stands of appropriate length so that when the device is on a leveled surface, the voltage reads zero. Yeah, I suppose you could say it's a title meter sensor, and it is going to be on a magnetometer.
Not knowing exactly what the setup is, it's hard for me to make much of a suggestion. Can you just tilt the thing by hand until you get zero, and measure that angle? It sounds like you are wanting to make an adapter pre-tilt thing to get zero out when the adapter+sensor are placed on a level surface, so just tilt the sensor until you get zero, and make something that provides that tilt. Better yet, squish the sensor down in some soft putty on a level surface and tilt it to get zero, then let the putty dry into a permanent adapter.
Yeah, I guess when I tilt the tiltmeter, I can get a zero voltage for both x and y. However, in order to make something that makes the tilt, my advisor wants me to calculate by how much for each side. So, since I have the x and y angles (calculated from the calibration curve fit equation which came with the device), and the length of each side, I guess I could use trig, maybe, the tan function to calculate the required height to make the correction right?
By the way, here's a link of the device
http://www.geosystems.com.au/pdpm02.html
Sounds right. Looks like a fun project!
