Why is it important to specify constant variables in a partial derivative?
The discussion revolves around the significance of specifying constant variables in the context of partial derivatives, particularly within thermodynamics and mathematical functions. Participants explore the notation and implications of partial derivatives, questioning the necessity of indicating which variable remains constant during differentiation.
  • Participants inquire about the meaning of notation in partial derivatives, specifically the use of subscripts to denote constant variables. They discuss examples from thermodynamics and mathematical transformations, questioning the need for explicit specification of constants when partial derivatives are defined.
The conversation is ongoing, with participants providing examples and raising questions about the implications of functional dependence in partial derivatives. Some guidance has been offered regarding the importance of specifying constants in thermodynamic contexts, but no consensus has been reached.
Participants reference specific mathematical examples and thermodynamic principles, indicating a focus on the nuances of notation and functional relationships. There are also off-topic discussions about formatting in the context of equations, which do not directly relate to the main topic.
loom91
Hi,
What does it mean to put a partial derivative in first brackets and put a right subscript to it of another variable?
[tex](\frac {\partial Y} {\partial Y})_T[/tex]
Thanks.
Molu
Hello Molu,
it is used to point out which variable should be treated as a constant while calculating the partial derivative.
One example from thermodynamics:
One relation for temperature T and energy E as a function of entropy S and volume V would be:
[tex]\left( \frac {\partial E(S,V)} {\partial S} \right)=\left( \frac {\partial E} {\partial S} \right)_V=T[/tex]
You can have a look at the following website to see more examples:
http://en.wikipedia.org/wiki/Thermodynamic_potentials
Regards,
nazzard
But since a partial derivative indicates that all variables except the variable of partial differentiation are to be kept constant, why is it necessary to specify which one is kept constant?
It may not always be the case.
Here's an example from Boas...
Let [tex]z = x^2 - y^2 <br /> <br /> x = r\cos\theta <br /> y = r\sin\theta<br /> <br /> z = 2x^2 - x^2 - y^2<br /> = 2x^2 - r^2 (1)<br /> <br /> z = x^2 + y^2 - 2y^2<br /> = r^2 - y^2 (2)<br /> <br /> z = r^2\cos^2\theta - r^2\sin^2\theta (3)[/tex]
Now calculate [tex]\left(\frac{\partial z}{\partial r}\right)_x (1) , \left(\frac{\partial z}{\partial r}\right)_y (2) , \left(\frac{\partial z}{\partial r}\right)_\theta (3).[/tex]
Off-topic: Why am I not seeing breaks between the equations? There are one or two lines between them in the code.
TeX ignores white space in equations unless you tell it to do otherwise.
If you want to introduce a space, you need to type "\ " instead of just " ". To put in a line break, "\\" should work.
Or, you could just use multiple TeX environments.
Because usually the functional dependence of the differentiated object is not specified by putting it in round brackets at the right of the object. Functional dependence in thermodynamics is essential, that's why it always matters what variable are to be kept constant.
Daniel.
