Is Installing Insulation a DIY-Friendly Task?
  • Thread starter Thread starter heartless
    Hard Insulation
The discussion revolves around the challenges and considerations of installing building insulation, particularly from the perspective of someone contemplating a summer job in this area. Participants share their experiences and insights regarding different types of insulation and the physical demands of the work.
  • Meta-discussion
  • One participant expresses uncertainty about the difficulty of insulation work, noting a lack of knowledge about insulation itself.
  • Another participant mentions various types of insulation, including blown-in foam, polystyrene sheets, and fiberglass batts, highlighting the challenges associated with fiberglass.
  • Some participants share personal experiences with fiberglass insulation, describing it as uncomfortable and irritating to the skin.
  • There is a suggestion that the job could serve as a valuable learning experience, particularly for someone considering a future in manual labor.
  • Concerns about the physical demands of the job are raised, with references to working conditions such as heat and the need for protective gear like gloves.
  • Participants note that the ease of installation may vary depending on the type of insulation being used.
Participants do not reach a consensus on whether insulation installation is easy or hard, as opinions vary based on personal experiences and the type of insulation discussed. The discussion remains unresolved regarding the overall difficulty of the task.
Some participants emphasize the importance of protective gear when handling insulation materials, particularly fiberglass, which can cause skin irritation. There is also a mention of the physical nature of the work, which may not be suitable for everyone.
Individuals considering a job in insulation installation, those interested in learning about different types of insulation, and anyone curious about the physical demands of manual labor in construction may find this discussion relevant.
heartless
I have an occasion to earn some money over the summer doing that building insulation or something like that, and I'm not sure whether I can handle it, meaning is it hard to do? After all, I don't know what insulation really is but from what I got by google, you just put some stuff to warm up a building. And by the way, shouldn't it be machines to do similar works?
--Thanks
that's not very fun...trust me
There are a lot of different kinds of insulation. 'Blown-in' foam or paper is fired out of a hose by air pressure. Polystyrene comes in sheets which you stuff in between the studs. It's nice to work with. The nasty one is fibreglass, which comes in batts. There's paper and/or foil on either side of it, but it'll still shed. No matter what you do, it'll end up getting into your clothes and skin. The effect is like nettles or poison ivy... not at all pleasant.
i made the mistake of grabbing a piece of fiberglass insulation once...
--Thanks
Heartless, you should take the job as a learning experience if nothing else. Find out if you enjoy manual labour outdoors. 10 or 20 years from now, when you're burning out at your desk job, you'll be glad you have the experience of physical labour to fall back on as a possible open door.
heartless said:
I have an occasion to earn some money over the summer doing that building insulation or something like that, and I'm not sure whether I can handle it, meaning is it hard to do? After all, I don't know what insulation really is but from what I got by google, you just put some stuff to warm up a building. And by the way, shouldn't it be machines to do similar works? -Thanks
You should be able to handle it. I did something similar during my college years. I did iron work (i.e. steel frame construction - the fun part) and metal sheet (wall, roof - tedious part - lots of screws) of metal buildings. Most were insulated and the insulation came in huge rolls up to 40-50 ft. We dropped the insulation in between the sheets and the steel frame. It was fine - unless the wind was blowing. :rolleyes: It's not fun being hot and sweaty and wrapped up in a roll of fiberglass insulation.
Anyway, as DaveC mentioned, consider it a learning experience while you earn some money.
As Danger indicated, how easy it is depends on the form of the insulation.
Dealing with insulation:
Don't forget your gloves,
and remember your gloves.
  • · Replies 20 ·
  • · Replies 46 ·
