| Thread Closed |
Sonic screw driver |
Share Thread | Thread Tools |
| Jul4-06, 01:19 AM | #1 |
Sonic screw driver
Ok it is a doctor who tool, but vibration is notorious for loosening nuts bolts
screws, otherwise there would be no need for locking wire, spring washers etc, so would it be possible to have a vibration producing tool that could undo stuborn fasteners, such a tool would be an invaluable tool for removing nuts/bolts/screws with damaged heads. |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Jul4-06, 06:36 AM | #2 |
Recognitions:
Yup. It's called a hammer drill or impact wrench.
| Jul4-06, 09:40 AM | #3 |
A sonic screwdriver - that's a great idea Woolie. No, not like Fred is thinking, more like those supersonic Gillette razors. Let me know when you need seed money, I'll invest.
| Jul4-06, 09:59 AM | #4 |
Sonic screw driver
It's certainly plausible. There are a couple of potential problems that I can see, along with one extra benefit.
1) the physiological effect upon the operator; depending upon the frequency and intensity, it can cause severe discomfort or tissue damage; white-noise headphones or such might be needed 2) the effect of transmitted vibrations upon other components of the target machine; chips could be jarred loose, calibration screws moved, etc. 3) the side-benefit that I can see is that ultrasonics will heat the material as well as just shake it; there might be enough dimensional distortion to assist in the loosening, as when you apply a torch to a bolt Too bad that there's no way to make it also tighten screws.
| Jul4-06, 08:16 PM | #5 |
(i.e. you can have ultrasound without pain/damage, though I don't know what freqs would loosen fasteners) However, why would you want to? Fasteners, and the tools that fasten them, are designed (or correctly operated) to avoid over-tightening. You should not have to (or want to) tighten a fastener tighter than you can um tighten it. Over-tightening is bad, but there's no such danger from over-loosening. |
| Jul4-06, 08:54 PM | #6 |
| Jul4-06, 09:39 PM | #7 |
While I realize that some ultrasonic frequencies are unnoticeable to humans, there are definitely some that are unpleasant and even dangerous. It's even worse when harmonics get weird. When a friend of mine was testing out a preliminary circuit for an ultrasonic weapon that I designed, his wife had to leave the house and he was wearing white-noise headphones at about 60dB to keep it back. That was at less than half power from a 15VDC source. Nice link, Woolie. I'm surprised that Nylocks rated so low. I've always used them or the spring washers instead of Loctite. |
| Jul5-06, 12:58 PM | #8 |
I have a really hard time believing that a spring type lockwasher actually AIDS in self loosening unless the parts involved (bolt, nut, washer, parts to be fastened, etc.) are the wrong fit to begin with.
| Jul5-06, 01:41 PM | #9 |
Recognitions:
Bolt science is a good site. They have some nice information. They even have a section on errors found in text books and Machinery's Handbook. |
| Jul5-06, 11:04 PM | #10 |
| Jul5-06, 11:41 PM | #11 |
| Jul6-06, 12:09 AM | #12 |
Looks like it has many different names : http://www.electroarc.com/index.cfm Edit: I guess that site essentially answers my previous question. |
| Jul6-06, 09:07 AM | #13 |
And here I've been wasting my time with EZ-Outs.
| Jul6-06, 01:53 PM | #14 |
Why not just buy an 800ft-lb impact wrench :D
| May31-09, 05:27 AM | #15 |
Buy a sonic screwdriver toy,then replace the insides with your fantasy.
| Jun6-09, 11:26 AM | #16 |
would not a sonic nut/bolt loosener require massive amounts of energy/intensity?
| Jun6-09, 01:00 PM | #17 |
Technically a sonic screwdriver should contain an adjustable sonic waves emiter that would push the bolt/nut or whatever the other thing is... To work like in DW it should also emit eloctromagnetic waves to affect the work of computers. Also it should possibly contain a tiny ( I mean really tiny-winy) magnetron to make light bulbs work (for example it is possible to light up a bulb in a micro oven without even being connected to it/even if the light bulb is NOT conected to a power source). By the way I'm currently trying to work it out myself using paperwork/Lightwave 3D and tearing old marker pens apart(and replacing their insides with self made LEDs an other stuff). P.S. Nice post by the way. =) |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Sonic screw driver
| Sonic reflexes | Biology | 4 | ||
| Non Magentic Screw Driver Magnetized | General Physics | 7 | ||
| Help on sonic boom | Mechanical Engineering | 12 | ||
| Sonic flow | Engineering Systems & Design | 12 | ||
| sonic booms | Introductory Physics Homework | 1 | ||
