New Reply
Electrically non-conductive thermally conductive material
Share Thread Thread Tools
Jul5-06, 11:15 PM   #1
Hi friends
Is there any material which is electrically non-conductive but thermally highly conductive.
Baltistani
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Sensitive bomb detector to rove in search of danger
>> PNNL-developed injection molding process recognized with emerging technologies award
>> How soon could car seats enter the 3-D comfort zone?
Jul6-06, 12:33 AM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Diamond!!!
Really, to get the best help here, you should describe your application and constraints.
Extra tip : Go to matweb.com -> property search. You can then search for materials with thermal conductivity > X and electrical resisivity > Y.
Jul6-06, 11:17 PM   #3
Actually I am trying to develop thermal control for a solar panel battery pack. When the batteries are extracting power they dissipate much heat and become very hot. We cant use a conductive material for wiping the heat.So please recommend some material which is a good heat conductor but electrical insulator.
Jul7-06, 08:47 AM   #4
Recognitions:
Quote by Baltistani
Hi friends
Baltistani
These are only qualitative quantities, high conductivity compared to what? You should decide what your requirements are before you go searching for a material.
You could try coating something like aluminum with a non-conductive coating. Just a thought.
BTW, why CANT you use a heatsink or something on the batteries? It's a fairly common practice I think.
Jul7-06, 11:35 PM   #5
Recognitions:
The standard heatsinking trick is to use a thin layer of insulating material (eg: mica sheet) as an electrical spacer between the two high conductivity materials.
But without a better description of a system (picture, specs, dimensions, requirements), it would be hard to help much more. It essentially comes down to doing the calculations and deciding what works for you.
You want the electrical resistance of your heatsink arrangement to be large compared to resistance-to-ground of the primary electrical path. How much larger? What level of current loss can you tolerate? Then you must have numbers for the power dissipation and a target value for the temperature difference you are willing to tolerate. This will set a lower bound on the thermal conductance you need. With these two numbers you then work on the geometry to see if you can achieve your target with real materials.
Jan30-08, 03:28 PM   #6
Hi,
Did you find any such material? I am looking for a similar one...
Thanks
Quote by Baltistani View Post
Hi friends
Baltistani
Jan30-08, 05:04 PM   #7
BACT DLC Diamond coating? May be what you're looking for. I think a Boron Nitride powder may have a thermal conductivity a bit too low for what's you're looking for. Check out www.bactusa.com.
Check out Boron Nitride powders still, though, may be of some use.
Jan31-08, 09:44 AM   #8
Recognitions:
Boron Nitride, Sapphire, or Alumina are both useful in some limited applications. The fact is that you need to decide exactly what kind of voltage you're insulating against, and how much heat you need to conduct.
I have heard that Boron Nitride is difficult to get in commercially pure grades, and is strongest as an electrical insulator in very thin sheets.
Jan31-08, 09:44 PM   #9
Recognitions:
Homework Helper Homework Help
Can you use a liquid? I have to believe various oils could be used. There's one used commonly in tranformers - now I forget the name. I'm sure someone can comment.
Jan31-08, 10:40 PM   #10
also, select graphite materials can be very thermally conductive, and can just be coated with a thin paralyne coating or something to give electrical insulation. this could give you something a lot lighter weight and with better corrosion resistance than some of the metal alternatives. Of course if money is no object, then yeah diamond is where it is at.
Feb8-08, 02:33 PM   #11
AlN seems to be good solution...Did any body work AlN?
I may get some samples next week. I'll try them and let you people also know...
Nov24-08, 12:05 PM   #12
This looks to be a common problem.
I too am looking for a thermally conductive electrical insulator for a 12v system. Space is a serious issue and one of the components on the PCB (aluminum) is not properly insulated from the board (and the manufacturer has no plans to rectify this any time soon). I'm hoping to use the PCB's housing as its heat sink (the housing is also the part's cathode) while using thin plastic as a thermal break/insulator to protect sensitive areas of the PCB's componentry. At some point on the back of the PCB there has to be a thermal connection between heatsink and PCB, I need to know what I can place there that wont short out the electronics but allow proper heat flow.
The dimentions are seriously small, I need something of a maximum 1 mm thickness, and the load on the PCB can get up to 45C when driven at high amperage. the surface area is 1 sq.cm
Any advice/solutions would be greatly appreciated, Thanks
Nov26-08, 01:47 AM   #13
Hi Tasty,
the thickness range of thermal conductive materials is 0.5mm to 13mm,i have delt with this issue before.and the thermal pads are placed between PCB and heatsink which is also available for your question.
Nov26-08, 01:56 AM   #14
Thermal conductive materials (of course Electrically insulator) provides an effective thermal interface between heat sink and electronic devices where uneven surface topography,air gaps and rough surface textures are present.
Dec18-08, 12:03 AM   #15
L62
I've used aluminum nitride as a thermally conductive electrical insulator in high vacuum applications
http://www.azom.com/details.asp?ArticleID=610
Dec18-08, 12:38 AM   #16
aluminum nitride its applications have been developed mainly for military aeronautics and transport fields,I think it takes the higher cost to be used in high vacuum applications, am i right?
Dec18-08, 01:19 AM   #17
L62
cost was not an issue for me (this was for basic research, not commercial application) so I admit I didn't pay attention to how much it cost; also I used it because for high vacuum we want minimal outgassing and AlN was sufficient for that criteria along with its electrical and thermal properties. But yes in general components that are high vacuum compatible tend to be quite expensive. (e.g. comparing the cost of a ultrahigh vacuum valve to a low vacuum valve, the cost can be 100 times more)
New Reply
Thread Tools
Similar Threads for: Electrically non-conductive thermally conductive material
Thread Forum Replies
Conductive liquids Chemistry 13
Conductive Glass Chemistry 33
non-coductive material but thermal conductive plates General Engineering 1
Dielectric material becomes conductive at High Frequency? Classical Physics 5
Water Non-Conductive? General Physics 8
