How do I transform a cross product using an orthogonal matrix?
The discussion focuses on transforming a cross product using an orthogonal matrix, specifically a rotation matrix around the y-axis defined as A=\left( \begin{array}{ccc}\cos{\alpha}&0&-\sin{\alpha}\\0&1&0\\\sin{\alpha}&0&\cos{\alpha}\end{array}\right). The user attempts to transform the vector \mathbf{B}=\mathbf{r} \times \hat{z} into a new coordinate system but encounters discrepancies with the expected results. The correct transformation yields \mathbf{B}' = y' \cos{\alpha} \hat{x}' - (x' \cos{\alpha} + z'\sin{\alpha}) \hat{y}' + y' \sin{\alpha}\hat{z}', indicating a misunderstanding of how components change under rotation and the significance of primed coordinates.
  • Understanding of orthogonal matrices and their properties
  • Familiarity with vector cross products
  • Knowledge of coordinate transformations in three-dimensional space
  • Basic concepts of tensors and their applications
  • Study the properties of orthogonal matrices in linear algebra
  • Learn about vector transformations under rotation
  • Explore the concept of primed coordinates in transformations
  • Review tensor operations and their relevance in physics and engineering
Students and professionals in physics, engineering, or mathematics who are dealing with vector transformations, particularly in the context of rotational dynamics and tensor analysis.
octol
I've been banging my head against this problem for some time now, and I just can't solve it. The problem seems fairly simple, but for some reason I don't get it.
Given the coordinate transformation matrix
[tex]A=\left( \begin{array}{ccc}\cos{\alpha}&0&-\sin{\alpha}\\0&1&0\\\sin{\alpha}&0&\cos{\alpha}\end{array}\right)[/tex]
show how
[tex]\mathbf{B}=\mathbf{r} \times \hat{z}[/tex]
transforms. Now how do I do this? For example, I've tried writing out the cross product, which becomes
[tex]\mathbf{B} = -y\hat{x} + x\hat{y}[/tex]
and then simply transforming this vector using the above matrix A, but it doesn't seem to work.
Any hints on how to think about this?
Why do you say "it doesn't seem to work"?
[tex]\left( \begin{array}{ccc}\cos{\alpha}&0&-\sin{\alpha}\\0&1&0\\\sin{\alpha}&0&\cos{\alpha}\end{array}\right)\left(\begin{array}{c}-y\\x\\0 \end{array}\right)= \left(\begin{array}{c}y cos(\alpha)\\ x\\y sin(\alpha)\end{array}\right)[/tex]
Is that what you got?
The transformation is, of course, a rotation around the y-axis, through the angle [itex]\alpha[/itex] so that the y component, here x, stays the same.
well yes that is what I got, but in the answer sheet it says the answer is supposed to be
[tex]\mathbf{B}' = y' \cos{\alpha} \hat{x}' - (x' \cos{\alpha} + z'\sin{\alpha}) \hat{y}' + y' \sin{\alpha}\hat{z}'[/tex]
which I simply don't understand, both how to get the y-component, or why the x,y,z components are all primed? Is it not supposed to be the same vector in a different coordinate system?
This problem is in the chapter about tensors and such, if that makes any difference...
  • · Replies 18 ·
  • · Replies 26 ·
