555 Timers, Button Presses and a little bit more
  • Thread starter Thread starter mushupork5
    Bit
This discussion focuses on utilizing 555 timers to control a valve and activate a switch for button pressing. The user seeks a straightforward solution involving a monostable circuit that triggers a button press with a single 555 timer. The conversation confirms that grounding the reset leg of the timer will allow for repeated button presses, simplifying the circuit design. A tutorial on ladder logic is recommended for further understanding.
  • Understanding of 555 timer configurations, specifically monostable mode
  • Basic knowledge of electronic components such as valves and switches
  • Familiarity with circuit design principles
  • Introduction to ladder logic programming
  • Study 555 timer monostable circuit design
  • Research valve control mechanisms in electronic circuits
  • Explore button press simulation techniques using electronic components
  • Learn about ladder logic programming for automation systems
Electronics enthusiasts, hobbyists designing automation projects, and engineers looking to implement timer-based control systems.
mushupork5
I am trying to set up some 555 timers to either:
1 - open a valve for a short period of time and then close it
2 - activate some sort of switch that will push a button to open the valve
it will be much more simple for me if I could find something that will push a button when triggered by a single 555 timer.
also, with that situation the pulse would just have to be run once and a simple monostable circuit could be built.
to have it push the button again all I would have to do is ground the reset leg, right? thanks PF
  • · Replies 29 ·
10K
