What Are the Answers to These Physics Questions?
  • Thread starter Thread starter dragun
This discussion addresses fundamental physics concepts, specifically inertia, terminal velocity, the impact of gravity on high jump records, and the Law of Conservation of Energy. Inertia is directly related to mass, while terminal velocity occurs when an object's acceleration reaches zero, indicating constant velocity. The location of the Olympics affects high jump records due to variations in gravitational pull based on distance from the Earth's center. The Law of Conservation of Energy holds true in closed systems where energy remains constant, unlike open systems where energy can dissipate.
  • Understanding of basic physics concepts such as inertia and acceleration
  • Familiarity with the principles of terminal velocity
  • Knowledge of gravitational effects on physical performance
  • Comprehension of closed versus open systems in energy conservation
  • Study the relationship between mass and inertia in classical mechanics
  • Research the concept of terminal velocity and its implications in free fall
  • Explore the effects of altitude on athletic performance, particularly in high jump
  • Investigate the principles of energy conservation in both closed and open systems
Students of physics, educators teaching physical science, athletes interested in performance metrics, and anyone seeking to deepen their understanding of fundamental physics principles.
dragun
Heres a couple of M/C questions i can't figure out maybe someone can help me out thanks.
1. The inertia of an object is most closely related to its ?
a)volume b)shape c)density d)position e)mass
2.An object in free fall reached its terminal velocity when it has : a)no foreces
b)a constant velocity
c)reached reached the acceleration due to gravity
d)a constant increase in velocitye
e)a constant decrease in velocity
Heres some S/A i can't figure out
3.explain how the location of the Olympics affects the record for the high jump?
4. You are riding your bicycle, describe a situation where you (& your bike) have a velocity northward, but an acceleration southward?
5. State under what conditions the Law of Conservation of Energy holds?
Although I am new I hope someone can help me out or answer the questions I am desperate all help is welcomed and thanks for your help dragun
1. Inertia is the tendency to remain at a constant velocity. Let's say you are riding on top of a car, and suddenly the car hits the brakes. Now what is going to keep you going: your volume, shape, density, position or mass? I'll also let you in on a little hint. Momentum is a factor here, and momentum = mv where m is the mass and v is the velocity, so...I hope you can figure this one out from that
2. When a terminal speed is reached, it means your acceleration is at 0. So what is the velocity if the acceleration is 0 (not looking for a number, more of a qualitative accessment of what is true of your velocity). Just so you know, the definition of acceleration is the rate of change of velocity. Hope you can figure this one out from this also.
3. The further you are from the center of the earth, the less the gravity of Earth affects you, so...just the difference between doing high jump very close to the center and very far away from it.
4. Like I said before, acceleration is the rate of change of velocity. So if your velocity is changing due to a southbound acceleration, what must be happening. Here is a specific example: The bike is going 5m/s north. You are accelerating 1 m/s^2 south. 1 m/s^2 south is the same as -1 m/s^2 north. Therefore what must be happening to your velocity? If this is happening, what is physically happening to the bike/rider (like what would an observer see).
5. Hmm...I think it has something to do with a closed system. If all the changes in energy occur in a closed system, the law of conservation of energy will hold. However, in an open-system, energy can be lost to unknown sources, and therefore it doesn't 'hold' as far as what one would calculate. I could be wrong thought. The answer may just be that it always holds.
Didn't want to give the answers away...Hope it helps :)
Thank you. You helped me a lot
