Pink in Visible Spectrum: Infrared to Ultra Violet
  • Context: High School
  • Thread starter Thread starter Gara
    Colour
The discussion revolves around the position of pink within the visible spectrum and the nature of color perception. Participants explore the relationship between pink, red, and blue, as well as the concept of color mixing and the absence of a specific frequency for pink.
  • Some participants question the placement of pink in the visible spectrum, noting that red and blue are at opposite ends.
  • Others propose that pink must exist between red and blue, as it is a color that can be perceived.
  • It is suggested that pink may be a superposition of different lightwaves with varying frequencies, rather than a single frequency.
  • Participants discuss the concept of saturation, indicating that pink can be seen as red mixed with a significant amount of white light.
  • There is a query about why pink lacks a distinct frequency while other colors, such as yellow, do have specific frequencies associated with them.
  • Some participants clarify that yellow is not created by mixing other colors, but rather by exciting specific color receptors in the eye.
  • One participant explains that mixing red, green, and blue light in certain proportions can produce white light, and adding more red results in pink.
  • It is noted that pink is not unique in lacking a specific frequency, with brown also cited as an example.
Participants express differing views on the nature of pink and its position in the spectrum, with no consensus reached on whether pink has its own frequency or how it relates to other colors.
There are unresolved questions regarding the definitions of color mixing and the perception of colors without distinct frequencies. The discussion also touches on the limitations of human color perception and the role of color receptors.
Gara
where is pink in the visible spectrum? it can't be between blue and red cos they're on the opersit ends...
after red is infer red, and after blue is ultra violet?
Science news on Phys.org
well it must be between red and blue because you see it...
an technically speaking infrared is before red:smile:
note: it is not a rule that a colour must have a single frequency. What we see as pink could be a superposition of different lightwaves with different frequencies
There is also importantly saturation, or the amount of white light (all frequencies) that accompanies the color. Pink is red with a lot of white.
so how come pink doesn't have its own frequency, but other colours that are made from mixing other colours, such as yellow do?
Yellow isn't made by mixing other colors together.
Read about it http://www.photo.net/photo/edscott/vis00010.htm . Our eyes have 3 color receptors: they are roughly red green and blue, but they overlap. Therefore we cannot tell the difference between a single frequency like yellow which excites both the red and green receptors, and a mixture of red and green in some proportion which results in the same excitation of red and green receptors.
Make a mix of equal parts red, green, and blue light, and you'll see the combination as white. Now add just a bit more red to the mix, and you'll have pink.
- Warren
Pink isn't the only one. Another example is brown and there are many others. Krab's explanation tells why.
well that clears that up :)
  • · Replies 40 ·
  • · Replies 0 ·
18K
