Imagine to be Pluto's surface, climate and atmosphere?
The discussion revolves around the imagined surface, climate, and atmosphere of Pluto, as well as the time it takes for sunlight to reach the dwarf planet. Participants explore various hypotheses and ideas related to these topics, including the implications of Pluto's elliptical orbit.
  • Some participants imagine Pluto to be extremely cold with a surface that may be icy or rocky.
  • There is speculation about Pluto's atmosphere being primarily nitrogen, which may freeze solid when far from the Sun.
  • One participant suggests that Pluto's atmosphere could be shared with its moon, Charon, raising questions about the dynamics of such a system.
  • Participants note that the time light takes to reach Pluto varies due to its elliptical orbit, with estimates ranging from about 4.1 hours at aphelion to 6.8 hours at perihelion.
  • Some express curiosity about the potential experiences of astronauts on Pluto, including the environmental conditions they might face.
  • There is a discussion about the implications of Pluto's eccentric orbit and how it compares to other celestial bodies, including Mercury and Xena.
Participants express a range of views on Pluto's surface and atmosphere, with no consensus reached on specific characteristics or dynamics. The discussion includes both agreement on certain aspects, such as the coldness of Pluto, and disagreement regarding the implications of its atmosphere and orbit.
Some claims about the atmosphere and its behavior are contingent on Pluto's distance from the Sun, and the discussion includes varying assumptions about the nature of its surface and atmospheric conditions.
zeus.hellas
Hi there. I have two questions to make. First how do you imagine to be Pluto's surface, climate and atmosphere? And second how much time does the sun light to reach Pluto? Please answer, i really want to know about these two things. Thank you.
Astronomy news on Phys.org
I imagine it cold, and light does not reach pluto in a constant time in order that its orbit is elliptical; but i don't see your problem...
Pluto is an average of 3.6 billion miles from the sun, which means it takes light about 5:20 to get there.
It is so small that it likely doesn't have much of an atmosphere. And it is extremely cold.
Born2Perform said:
<...> and light does not reach pluto in a constant time in order that its orbit is elliptical<...>
What does light-time have to do with eccentricity of an orbit?
The time light takes to reach Pluto varies because the distance to Pluto varies. The distance varies because of eccentric orbit.
That much I knew..:biggrin:
That would apply to all planets and anything else in an elliptical orbit, like all orbits are. I thought that the OP (the original post was edited as shown by my first answer to quote above) was asking or implying that the light-time had an effect or "cause" in Pluto's large eccentricity.
Should have known..:frown:
There is not really a problem. I mean i don't want to visit Pluto. I just want to make a picture of what possible experiences would a possible future human mission on that planet. What could be life iside a base and what would be the feeling out of it. What will the astrounauts will see and feel everyday on that planet?
The atmosphere on Pluto is actually quite an interesting topic. The theory goes that Pluto has an atmosphere that is mostly nytrogen (like Earth's), but this atmosphere only exists when Pluto is inside or close to being inside Neptune's orbit. The rest of the time, the planet is so far from the Sun that the atmosphere freezes solid and becomes the surface of the planet; a surface of Nytrogen ice.
Since I don't think it has enough gravity to hold on to a nytrogen atmosphere, this makes me wonder if Pluto is getting smaller with each orbit, like a comet burning of its volitals every time it passes through the inner Solar System.
Also, I think IL makes a point worth noticing. Pluto's orbit is far nore eliptical than any (other) planet's. I ran some quick numbers, and it looks to me as if Sunlight can reach the surface in just over four (4.1) hours at aphelion, and just under seven hours (6.8) at perihelion. Quite a discrepency.
Pluto
Greetings,
I recall some Pluto related knowledge i would like to share, which i found from a Lowell observatory astronomer's website on the imaging of the planet (Marc Buie http://www.lowell.edu/users/buie/pluto/pluto.html" .
Regarding how I would imagine being on Pluto is not easy to describe, as a specific experience i think it should be similar to my initial visits to the Grand Canyon, but here is an artist's representation upon a similar object: Sedna, a Kuiper belt object--http://antwrp.gsfc.nasa.gov/apod/image/0406/sednaIll_schaller_full.jpg" .
Realistically, I think steps should be considered if you wish to figure out how space exploration comes about to orient yourself in the field; mainly what "approximation" is there here on Earth that can prepare humans on interplanetary travels? I think anecdotes of scientists from expeditions to Antartica is a good start--(astro)geologists go there to search for meteorites.
Pluto's atmosphere - when it's warm enough to be gaseous instead of frozen - has such a low gradient (drop in pressure with altitiude) that it shares it with its moon Charon.
Pluto's surface would be solid, rocky, icy. Not white ice though, dark ice. And the ice is so cold that it's hard like iron. It would ring when you struck it. Depending on the "season" which each last 60+ Earth years, there could be frost or mist, as the atmo freezes out or sublimates.
Pluto and Charon share an atmosphere??:eek: If true, that's very interesting. Wouldn't that create friction that would cause them to spiral towards each other?
LURCH said:
...Pluto's orbit is far nore eliptical than any (other) planet's...
Mercury comes close (.206 vs .249). And Xena (.442) (depending on whether or not you consider it a planet) has a higher eccentricity than Pluto.
  • · Replies 33 ·
  • · Replies 31 ·
