Negative numbers to non-interger powers
  • Context: Undergrad
  • Thread starter Thread starter scott_alexsk
    Negative Numbers
The discussion revolves around the evaluation of negative numbers raised to non-integer powers, specifically focusing on the example of -3 raised to the power of 1.5. Participants explore the implications of complex numbers in this context, examining different approaches and interpretations of the mathematical expressions involved.
  • One participant suggests that -3^1.5 can be expressed as -3^{3/2}, leading to the square root of a negative number, indicating a solution in the imaginary plane.
  • Another participant elaborates on the use of complex numbers, defining i as the square root of -1, and presents a method to express -3^1.5 in terms of complex numbers, resulting in -i3√3.
  • There is a clarification that -3^{1.5} results in -3√3, while (-3)^{1.5} leads to 3i√3, highlighting the distinction between the two expressions.
  • Some participants discuss the multi-valued nature of complex functions, noting that (-3)^{1.5} has two potential values: 3i√3 and -3i√3.
  • One participant raises a question about the conditions under which negative numbers raised to irrational powers yield real numbers, suggesting that negative reals raised to irrational powers cannot be real.
  • There is a mention of the confusion surrounding the rationality of the exponent and its implications for the resulting values.
Participants express differing views on the evaluation of negative numbers raised to non-integer powers, with no consensus reached on the correct interpretation or outcome. The discussion remains unresolved regarding the conditions under which these expressions yield real or complex results.
Participants note the importance of distinguishing between -3^{1.5} and (-3)^{1.5}, as well as the implications of using irrational exponents on negative bases. There are unresolved questions about the nature of solutions when dealing with complex numbers and the rationality of exponents.
scott_alexsk
Hello,
How would you determine the value of such numbers as -3^1.5?
Thanks,
-scott
Mathematics news on Phys.org
[tex]- 3 ^{ 1.5} = - 3^ {\frac 3 2}[/tex]
Do either the square root or the cube first, either way results in the square root of a negative number. So the solution lies in the imaginary plane.
Have you ever worked with complex numbers before? Define i = (-1)^0.5
-3^1.5 = (3)^1.5 * (-1)^1.5 = 3^1.5 * (-1)^1 * (-1)^0.5 =
[tex]-i3\sqrt{3}[/tex]. By extension of this procedure one can define negative numbers to any power.
hmm... idk i would just put it in the caculator :D but i do know that a negative number squared by an odd nuber is X i idk if this helps
As you wrote it, you do not have a square root of a negative number:
[tex]-3^{1.5} = -3^{\frac{3}{2}} = - \sqrt{27} = - 3\sqrt{3}[/tex]
On the other hand,
[tex](-3)^{1.5} = (-3)^{\frac{3}{2}} = \sqrt{-27} = 3i \sqrt{3}[/tex]
[tex](-3)^{1.5} = (-3)^{\frac{3}{2}} = \sqrt{-27} = \sqrt{27} \sqrt{-1} = \boxed{3i \sqrt{3}}[/tex]
not
[tex]-3i \sqrt{3}[/tex]
*Also, note that:
[tex]\forall x < 0, x^k \notin \mathbb{R} \; \text{ if } \, k \notin \mathbb{Q}[/tex]
You posted this 9 times?! I deleted the other 8.
On the other hand,
A good point!
not
While "the" square root of a positive real number is define to be the positive root, that is not true for complex numbers, where most functions are "multi-valued". (-3)1.5 has two values,
[itex]3i\sqrt{3}[/itex] and [itex]-3i\sqrt{3}[/itex]
*Also, note that:
?? or even if k is rational: 1.5 is certainly rational! Did you mean
[tex]k \notin \mathbb {I}[/tex]?
Not really ~~
The problem was that I couldn't edit the [tex]\LaTeX[/tex] just by using the "Edit" or "Go Advanced". I had to post, delete, and repost :frown: (for some time, so it "appeared" as though I posted nine times)
I see; so the answer is then
[tex]\pm 3i\sqrt{3}[/tex]
I didn't intend to be an 'if and only if' statement...
Halls of Ivy said:
Did you mean [tex]k \notin \mathbb {I}[/tex]?
Not really//
my statement there wasn't necessarily for scott_alesk's question;
it's just a property I like, that's related to complex numbers (~which this thread involves~).
What I meant to say was that any negative real raised to an irrational power cannot be a real number (the imaginary part of all solutions for [itex]x^k[/itex] is always nonzero if [itex]x<0[/itex] and [itex]k \notin \mathbb{Q}[/itex]).
(However, is this also the case if [itex]k\notin \mathbb{Z}[/itex] ? But doesn't [itex](-1)^{1 / 3}[/itex] have one real solution equal to [itex]-1[/itex] ?)
Sometimes after you've changed the latex by editing and committed the changes, they don't show until you refresh the page.
My reader is so messed up it doesn't always show the changes even after "refresh"! Sometimes what I do is make the changes, copy it, then delete the post (clicking "physically remove") and paste into a new post.
~That's exactly what I did! (..."nine times" :frown:)
Note the part about clicking "physically remove"!
I often open the image itself in a new window, and reload that. It's easy to do in opera, but I don't know about the other major browsers.
  • · Replies 18 ·
  • · Replies 18 ·
