Thermal conductivity of stainless steel
The discussion revolves around a problem involving thermal conductivity and heat transfer in a stainless steel tea kettle containing water. Participants explore the relationship between the heat energy supplied to the water and the heat conduction through the kettle's material.
  • Participants discuss calculating the energy reaching the water and its relation to the heat transfer through the kettle. Questions arise about the concepts of heat conduction, convection, and the temperature difference between the kettle and the water.
Some participants have provided guidance on how to approach the problem, emphasizing the need to clarify energy units and the relationships between heat transfer concepts. There is an ongoing exploration of the calculations involved, with no explicit consensus reached on the final answer.
Participants note the importance of using correct units for energy and power in their calculations. There is also mention of assumptions regarding heat loss and the need for clarity in the relationships between different forms of heat transfer.
xyz
Hi...
there is a question i can't figure out. "A 400-g stainless steel tea kettle containing 500g of water is on top of the stove.The portion of the tea kettle that is in contact with the heating element has an area of 0.005m^2 and is 2.5mm thick. At a certain moment,the temperature of the water is 75C,and it is rising at the rate of 4C per minute. What is the difference in temperature between the inside and the outside of the bottom of the tea kettle? the thermal conductivity of stainless steel is 16.3W/(m K) and the specific heat is 448 J/(kg K)."
Thank you for any replies!
Well.
Working on the laws of this forum, we are not able to give you ready answers, you should tell us where you got stuck !
I will give you some clues ...
Knowing that the temprature rises in a certain amount in each time unit, and knowing the specific heat of water (and the mass of water), you can calculate the amount of energy that is reaching the water in time unit (or the heat power on water).
Now this is supposed to equal the heat power giong through the kettle (since the heat is coming from it to the water, and assuming there is no heat lost), if you equal both of them, you should figure out [del]T.
If you tell us where you got stuck, we may be more usefull :smile:
humm...thanks:wink:
I am just confused the relationship of heat conduction,convection and radiation, like the heat flows from the stove,then the heat flow into the tea kettle,it causes different temperatures between the tea kettle and water.
In this case,i have to compute the Temperature of the tea kettle rising per minute.Right??
Hi...STAii
i calculate the amount of energy that is reaching the water in 1 minute, m c [del] T=0.5kg*4186j/(kg K)*4C=8372j.
8372j equals to the heat power going through the kettle,
8372j=k A [del]T *60s/L =16.3W/(m K)*0.005m^2* [del]T*60s/0.0025
so i compute [del]T=4.28C...the difference in temperature between the inside and the outside of the bottom of the kettle is 4.28C...
Am i right? looking forward ur reply...
The concept is right (i didn't look into the numbers ..), but there are some little notes.
"8372j equals to the heat power going through the kettle"
Joule is not a unit of power, it is a unit of energy, so you either have to say :
"8372 j/min equals to the heat power going through the kettle"
or say:
"8372j equals to the heat eneryg going through the kettle in a single minute"
Otherwise, everything is fine.
Also note that it is convenient to use SI units, like you could have used the unit of second for time, and therefore found the heat power reaching the kettle in Watts, and used the following equation to solve.
P(ower In Conductivity) = (k*A*[del]T)/L
Hope i helped.
10K
