Register to reply
Adding Net Ionic Equations
by yellowduck
Tags: adding, equations, ionic
Share this thread:
yellowduck
#1
Jul19-06, 08:34 PM
P: 16
This should be easy but I feel there is something I am mission
I need to write the net ionic equations and then add #1 & #2 and compare to #3.
Equation #1 - write net ionic equation for dissolution of solid NaOH in water
Equation: NaOH (s) + H2O --> Na+ (aq) + OH- (aq) + H2O (l)
Net: NaOH (s) --> Na+ (aq) + OH- (aq)
(it says in the book to seperate strong bases such as NaOH but if I do all ions cancel out???)
Equation #2 - write net ionic equation for aqueous soloutions of NaOH & HCl
Equation: NaOH (aq) + HCl (aq) ---> NaCl (aq) + H2O (l)
Net: OH- (aq) + H+ (aq) --> H2O (l)
Equation 3: Solid NaOH and aqueous HCl
Equation: NaOH (s) + HCl (aq) ---> NaCl (aq) + H2O
OH- (s) + H+ (aq) --> H2O (l)
Add #1 & #2
This is where I get lost. I think it should be net equation #2. The difference is in the solid/aqueous state.
thanks
Phys.Org News Partner Science news on Phys.org
Wildfires and other burns play bigger role in climate change, professor finds
SR Labs research to expose BadUSB next week in Vegas
New study advances 'DNA revolution,' tells butterflies' evolutionary history
PPonte
#2
Jul19-06, 08:48 PM
P: n/a
1. Add #1 to #2.
[tex]NaOH \text{(s)} + OH^- \text{(aq)} + H^+ \text{(aq)} \longrightarrow Na^+ \text{(aq)} + OH^- \text{(aq)} + H_2O \text{(l)}[/tex]
2. Delete the common compounds on both members of the equation.
[tex]NaOH \text{(s)} + H^+ \text{(aq)} \longrightarrow Na^+ \text{(aq)} + H_2O \text{(l)}[/tex]
yellowduck
#3
Jul19-06, 09:08 PM
P: 16
Is it possible that I have equation #3 wrong.
Should the net ionic equation look like your final answer above?
PPonte
#4
Jul19-06, 09:44 PM
P: n/a
Quote Quote by yellowduck
You have #3 correct, I think.
sdekivit
#5
Jul20-06, 02:44 AM
P: 92
Solid NaOH in HCl-solution. The HCl-solution contains [tex]H^{+}[/tex] and [tex]Cl^{-}[/tex] but the solid is just NAOH. So the reaction at 3 should be:
[tex]NaOH(s) + H^{+} \rightarrow Na^{+} + H_{2}O[/tex]
dissolver
#6
Aug6-06, 02:56 PM
P: 16
So if it states solid, then you must write out the entire formula even in the net ionic equation (because it is infered that the solid is not dissolved in the solution)?
Register to reply
Related Discussions
Chemistry - Net ionic equations, ionic solids..! Biology, Chemistry & Other Homework 2
Ionic equations? Biology, Chemistry & Other Homework 2
Net Ionic Equations Biology, Chemistry & Other Homework 5
Ionic equations Chemistry 8
Net ionic equations Chemistry 1
