Complex Solutions to Quadratic Equations: Am I Right or Did I Mess Up?
  • Context: Undergrad
  • Thread starter Thread starter wooby
The discussion revolves around finding complex solutions to the quadratic equation z² + z + 1 = 0. Participants explore the nature of the roots, the validity of complex numbers in the context of the equation, and the application of the quadratic formula.
  • One participant concludes that there are no solutions because the real component must be zero, which cannot be satisfied in the reals.
  • Another participant asserts that a polynomial of degree n has exactly n roots over the complex numbers, implying that solutions exist.
  • Questions arise about whether a complex root can be valid if the real component is considered.
  • Participants discuss the real and imaginary components of the equation, noting that the real part simplifies differently than initially assumed.
  • There is a debate about whether the imaginary part must equal zero for valid solutions, with some arguing that y can take non-zero values.
  • Simultaneous equations derived from the real and imaginary parts are proposed as a method to find solutions, with references to the quadratic formula and the fundamental theorem of algebra.
  • One participant suggests that the quadratic formula should yield the same solution set as the simultaneous equations, emphasizing the need for real solutions for x and y.
  • Another participant points out a potential oversight in the application of the quadratic formula regarding the discriminant.
Participants express differing views on the necessity of the imaginary part being zero and the validity of complex roots. The discussion remains unresolved regarding the implications of these points on the solutions to the equation.
Participants reference the quadratic formula and the fundamental theorem of algebra, but there are unresolved assumptions about the nature of the roots and the treatment of real versus complex components.
wooby
Find all complex z = (x,y) such that [tex]z^2 + z + 1 = 0[/tex]
I conclude that there is no solution set because for the real component to be 0 one must be able to solve [tex]x^2 + x + 1 = 0[/tex] and such a solution does not exist in the reals.
Am I correct or did I mess up in my algebra some where resulting in the quadratic above?
Thanks
A polynomial of degree [itex]n[/itex] ([itex]\ge 1[/itex]) always has exactly [itex]n[/itex] roots over the complex numbers.
Do you remember something about a formula that gives solutions to quadratic equations (a "quadratic formula," perhaps?)? :biggrin:
Yes, however, since x is the real component, is a complex root for x a valid answer?
if z=x+i*y is a root then
(x+i*y)^2+(x+i*y)+1=0
the real part of the left hand side is x^2-y^2+x+1, not x^2+x+1 (I think that's what you're saying?)
correct, however, since we are finding solutions for 0, the complex value is zero only when y = 0 thus the -y^2 drops off the real portion.
or am I incorrect in doing that?
No, y does not have to be zero.
(x+i*y)^2+(x+i*y)+1=(x^2-y^2+x+1)+i*(2*x*y+y)
If x+i*y is a zero, this gives two equations:
2*x*y+y=0
x^2-y^2+x+1=0
y does not have to be zero for there to be a solution. Take x=-1/2, etc.
(setting real and imaginary parts to zero to try to find a solution here is not ideal at all, you have the quadratic formula right? You also know the fundamental theorem of algebra? Maybe not, it's what Data mentioned- a poly of degree n will have n complex roots, counting multiplicities)
Yes, you are incorrect in doing that. The imaginary part of the LHS (in shmoe's scheme) is [itex]2xy + y[/itex], so it depends on x too. You can solve the simultaneous equations
[tex]\{x^2-y^2+x+1 = 0, 2xy + y =0\}[/tex]
and they should give you the same solution set as the quadratic formula (for [itex]z=x+iy[/itex]).
Edit: Since this seems like it might be the source of your confusion, I will note that you should definitely only accept REAL solutions for [itex]x[/itex] and [itex]y[/itex] here (it doesn't make any difference for [itex]z[/itex], you will still have only at most two solutions for that. But you assume that [itex]x[/itex] and [itex]y[/itex] are real here). You will still find two solutions for [itex]z[/itex] (or one solution representing a root with multiplicity 2).
"Finding solutions for 0"? y is the imaginary part of the root, z, and that is definitely NOT 0. It is both real and imaginary parts of the entire
(x^2-y^2+x+1) + i(2xy+ y) that must be 0. That is, you must have
x^2- y^2+ x+ 1= 0 and 2xy+ y= 0. Yes, the latter can be factored as
y(2x+ 1)= 0 so either y= 0, in which case we must have x^2+ x+ 1= 0 which has no real roots, or2x+1= 0 so x= -1/2, in which case we must have 1/4- y^2- 1/2+ 1= 3/4- y^2= 0 so [itex]y= \pm\frac{\sqrt{3}}{2}[/itex]: the roots are itex]z= -\frac{1}{2}\pm\frac{\sqrt{3}}{2}[/itex].
Of course, as Data originally pointed out, you could just use the quadratic formula:
[tex]z= \frac{-1\pm\sqrt{1- 4}}{2}= \frac{-1\pm\sqrt{2}}{2}[/tex]
Thanks everyone.
I can't believe I missed such an obvious solution to the I am z portion.
HallsofIvy, should you have a -3 under the radical in your last line?
  • · Replies 17 ·
