Thread Closed
Does a current produce an electric field?
Share Thread Thread Tools
Jul24-06, 08:41 AM   #1
A current will produce a magnetic field but I don't think an electric field will be produced. Why is that? Why is a test charge affected by a static charge but not a moving charge?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Jul24-06, 08:52 AM   #2
Mentor
Quote by pivoxa15
Because a current-carrying wire (I assume that's what you are referring to) has no net charge (nor is there a changing magnetic field, assuming a constant current).
If it were a current of just charge carriers without a wire--a beam of electrons in a vacuum chamber, for instance--then there would certainly be an associated electric field.
Why do you think that?
Jul24-06, 09:09 AM   #3
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Another way to look at it is that a varying magnetic field will produce an electric field but a (constant) currant only produces a static magnetic field.
Jul24-06, 08:51 PM   #4
Quote by Doc Al
Why is this the case? Is it because the wire acts as an insulator so charges inside the wire will not show up on the outside of the material so anything outside will not know of any electric charges anywhere.
Jul24-06, 09:01 PM   #5
Quote by Doc A
Maybe I was wrong. A test charge should be affected by a moving charge just as much as it is affected by a static charge. Given that there is nothing else that could affect the two charges in the surrounding area.
Jul25-06, 06:09 AM   #6
Recognitions:
Quote by pivoxa15
Jul25-06, 08:10 AM   #7
Mentor
(Regarding the current-carrying wire)
Quote by pivoxa15
Realize that by definition an insulator is something that cannot conduct an electric current; the wire, of course, is a conductor not an insulator. But if you look at a section of the wire, what's the net charge on it? Zero! So the net electric field is also zero.
Perhaps you are thinking that the current is "extra" charge added to the wire? Not so. It's just a forced movement of the electrons that already exist in the wire. (Any electrons added at one end are being removed at the other end.)
(Regarding the test charge)
Quote by pivoxa15
Right.
Jul25-06, 08:57 AM   #8
Mentor
To make an analogy between wire and a water-pipe, a wire without any current flowing through it is not like an empty pipe. Rather, it's like a pipe that is full of stationary water.
Jul25-06, 09:15 AM   #9
A current in a wire can be viewed as the two types of charges moving in opposite direction. Say in a horizontal wire, from left to right, negative charges moving to the left and positive charges moving to the right. So for a test test charge at rest outside the wire, the wire will be neutral.
So remember that, there is always the two kinds of charges moving in the wire.
Jul25-06, 09:45 AM   #10
Mentor
Quote by borisleprof
In an ordinary metal wire, the only charges that are moving are the negative electrons. The positive charges are fixed in a lattice and are not free to move. (This is not the case in many other kinds of materials that can conduct a current.)
Don't confuse the direction that the electrons actually move with the direction of "conventional" current flow, which is opposite to the direction the electrons move. (The direction of conventional current was defined with respect to positive charges before it was understood that negative electrons carried the current.) So if the electrons moved from left to right, we say the current moves from right to left.
Jul25-06, 11:15 AM   #11
Recognitions:
Homework Helper Homework Help
Quote by Doc Al
I think you mean the net electric field contributed by that section of wire is zero. Of course, there must be an electric field in the wire if current is flowing.
AM
Jul25-06, 11:26 AM   #12
Mentor
Right. Good catch!
Jul25-06, 09:43 PM   #13
Quote by Doc Al
Right.
I was thinking of a (thick) wire used in the home such as the wire that connects the CPU to the main electrical socket (what do you call these?) These have an insulating material around the wire, otherwise you would be in great danger. So in that way a test charge outside would not sense the charges inside the wire whether it is moving or not.
But we are considering a plain wire so I will stick to that. If we have a circuit with charges flowing, lets consider the whole circuit by enclosing a surface over it. The charges may be moving inside this surface but they will always be inside it hence a net charge exists and electric field lines will extend outside and a test charge will feel it. But this contradicts your explanation. Maybe your explanation works only when the wire is infinitely long?
Why is it that a current of just charge carriers without a wire--a beam of electrons in a vacuum chamber, then there would be an associated electric field? Is it because we are not measuring the electric field with respect to a portion of space such as wire but always to the charges themselves. Hence the Electricfield is moving with the charge carriers?
Jul25-06, 11:07 PM   #14
Recognitions:
Quote by pivoxa15
You seem to be forgetting that the wire contains as many protons as electrons. The protons are fixed and don't move. The electrons move but for any given volume, the number leaving is equal to the number entering, so there is no change. The ratio of electrons and protons always remains at 1.00000000000...
An electric field (created by the potential difference between cathode and anode) is required in order for electrons to leave the cathode and create a current. The electron flow does not affect the electric field between the anode and cathode. That field depends only on the potential difference that is applied.
AM
Jul27-06, 12:50 AM   #15
Quote by Andrew Mason
AM
So you are saying that copper when in a block of solid must be electrically neutral? How can you tell?
If it must be neutral than that explains why the electrons on a current carrying wire has no electric field associated with them because there will always a positive charge nearby. This is what Doc Al said. Now I understand.
However, charges moving in a vacuum will have an electric field because there are no protons to cancel their charges.
Jul27-06, 01:26 AM   #16
Recognitions:
Quote by pivoxa15
It doesn't have to be electrically neutral. You can easily create a charged conductor. An airplane frame is often a charged conductor as it flies, so all of the electrical circuits connected to the frame will have a static charge. But that static electric charge that does not change when current flows or stops flowing in those circuits.
And that is why a cathode ray oscilloscope works: the electron beam is deflected by electric charge on plates placed horizontally and vertically around the electron beam.
AM
Thread Closed
Thread Tools
Similar Threads for: Does a current produce an electric field?
Thread Forum Replies
Electric field from a wire with a stationary current Advanced Physics Homework 2
Electric Field near current carrying wires Advanced Physics Homework 6
Wire with Current and electric field Introductory Physics Homework 1
whats the difference between an electric field and an electric current? General Physics 3
Generating Current in an Electric Field Classical Physics 14
