Radiated power, what does this even mean?
  • Thread starter Thread starter ness9660
    even Mean Power
The discussion revolves around the concept of radiated power in the context of a light bulb, specifically a #50 bulb with a specified output of 1 MSCP. Participants are exploring the relationship between electrical energy, visible light output, and the definition of radiated power.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants are attempting to understand why the calculated output of 18.4mW is not considered the radiated power of the bulb. Questions are raised about the conversion of electrical energy to heat and light, and the mechanisms behind electromagnetic radiation production.
The discussion is ongoing, with various interpretations being explored regarding the nature of radiated power and the processes involved in light production. Some participants have offered insights into the mechanisms of radiation, while others are questioning assumptions and seeking clarification on specific concepts.
There is a focus on the efficiency of the bulb and the distinction between different forms of energy conversion, including visible light and infrared radiation. Participants are also discussing the differences in behavior between electrons in a resistance versus those in a conductor.
ness9660
The light bulb used in this experiement is a #50 bulb, which has an output of about 1 MSCP. The output of the bulb is specified by the manufacturer. The MSCP of the bulb can be converted to units of power using the following relations:
Lumens= 4(pi) * MSCP
1 lumen = 1.464 @ 555nm
After the conversion the output of the #50 bulb is about 18.4mW. Assuming the efficiency of the bulb in converting electrical energy into visible light is 5%, what is the radiated power P (in mW) of the light bulb?
Honestly, I am not even sure exactly what radiated power means. Why is the 18.4mW not the radiated power of the light bulb?
I thought electrical energy was essentially work, which is a product of power and time, so how could radiated power be anything except 18.4mW? Are they referring to 0.5% * 18.4 mW?
Let me take a wild guess here.
A light bulb is a resistance. When current passes through it, collisions of the electron of the current with the atoms the the resistance happen. As a result, the speed of the atoms in the resistance increases. "Electrical energy" is converted into "heat energy", and we are told by the fabricant that this conversion happens at a rate of 18.4 mJ/s.
I'm not sure how the radiation comes into play here, but it is possible that it is emited when the excited atoms fall back to a state of lower energy. An electromagnetic wave is then produced. So heat is transformed into radiation in this way. And we are told that 5% of the 18.4 J transformed per second end up in this way (as visible light).
So all that to say "ya, 0.5% * 18.4mW" would be the answer.
The bulb radiates power both in visible light (5%) and other forms of invisible radiation (mostly infrared).
- Warren
Ok, so 18.4mJ is the amount specifically converted to electromagnetic radiation per second. And 5% of that 18.4mW is light in the visible spectrum.
chroot, how are the electromagnetic radiations produced? I.e. as a result of what mechanisms?
Light is produced when charged particles accelerate. In the situation you are describing electrons collide (i.e. accelerate) with ions in the filament thereby radiating.
Electrons also collide with each other in the conducting wire. According to my notes, a classical analysis gives an intercollision time of 2 fs for a coper wire at 300K. But we rarely see visible light coming out of coper wires. So what's different in a resistance that makes the electron accelerate more as a result of collisions with the atoms of the resistance?
And a subquestion if I may: why do we say that electrons emit an electromagnetic wave when they accelerate but not when they travel at constant speed? In other words, what's different btw the "emited radiation" caused by acceleration, and the simple propagating deformation of the electric field caused by a moving charge?
Anybody?
Second question: A charged particle that is moving at constant speed (assuming no external fields) is not absorbing or emitting energy. It is simple inertial movement.
The accelerated particle needs energy inputs and outputs. Energy is loss when a particle loses energy and it has to go somewhere so it emits the photon (Conservation of Energy). The photon will then accelerate another particle when it is absorbed elsewhere.
The simple deformation of an electric field is just an abstract construct and really doesn’t mean anything physical. If there is an external field, the particle will be accelerated and it will be absorbing and emitting photons.
First question: Heat up a copper wire enough (like the filament in the bulb) and it will emit visible light too. The heat energy knocks electrons out of their orbits and as they drop back they emit visible radiation. There is nothing special about the resistance, it is just that it would take an enormous amount of current to heat the copper that much (and it would melt).
(I am still learning this stuff so tell me if I am wrong! But I believe what I said is correct)
Hi interested_learner, thanks for the reply.
What do you mean by " The accelerated particle needs energy inputs and outputs."? In a gravitational field, there is no analogue to photons emited by decelerating charges. So there does not need to be an "output" other than potential energy. (imo :smile:)
Of course, electrons collide with each other but since they are like-charged their radiated fields cancel to lowest order. Much more power is emitted in electron-ion collisions.
  • · Replies 16 ·
9K
10K
