| Thread Closed |
Is time just an illusion? |
Share Thread | Thread Tools |
| Sep13-07, 04:39 PM | #528 |
I suppose Doctordick is going to be back soon, so time to reply...
Seems you've met a lot of famous people btw :) To summarize where I'm at; I understand the addition of invalid ontological elements, in order to: - make the number of elements the same in each "present". - make sure there are no identical present (to make "t" retrievable). - make sure there are no identical presents even if any given single ontological element was removed from any given present (to make sure a missing element could be retrieved from the table if we were given all but one element) (Btw, since each tau was associated with a specific X, they together constituted a "single element", i.e. a "missing element" always refers to a "x & tau"-pair... Right? Thought I'd say it out loud since this can cause confusion) --- Then, a function "f" was defined, as the function which outputs the missing element when input with any given "present" missing any given element. Seen as a vector function: [tex]\vec{(x,\tau)}_n= x_n\hat{x}+\tau_n\hat{\tau} = \vec{f}((x,\tau)_1,(x,\tau)_2, \cdots, (x,\tau)_{n-1})[/tex] (I don't know what "X hat" and "tau hat" mean, and so I couldn't figure out what the middle part of that equation says) --- Then, a function F was defined, as the difference between the missing index and the result of the function "f". I.e; [tex]F((x,\tau)_1,(x,\tau)_2, \cdots, (x,\tau)_n})= \vec{(x,\tau)}_n - \vec{f}((x,\tau)_1,(x,\tau)_2, \cdots, (x,\tau)_{n-1})\equiv 0[/tex] (Perhaps I asked this before but forgot; what does [tex]\equiv[/tex] mean there exactly?) Would it be correct to say that F is a function which "tests" every element of a "present" with some function f? Or is it more proper to just say it is "any function which returns 0 when its input with a full present"? --- And here I start to struggle little bit more. I'm note sure how does the above turn into: [tex]\sum_{i \neq j}\delta(x_i -x_j)\delta(\tau_i -\tau_j) = 0[/tex] I understood this is just one of many functions that satisfies the requirements for F, and since we have chosen it as F, it will have an effect on what labels we put on the ontological elements. To quote you: "It is thus a fact that the equation will constrain all labels to be different and any specific collection of labels can be reproduced by the simple act of adding “invalid ontological elements” until all the wrong answers are eliminated." What I don't understand is the latter part of that sentence. Perhaps I have misundestood something, but maybe you could just explain in more detail, how is it that it reproduces a specific collection? --- Then we get to the propability function. Thank you for the helpful information about "complex conjugate". I understand the need of squaring psi, but I don't know what the psi itself was to accomplish. I went back to the old posts, but all I can find is the idea of seeing any result of any function as a vector. (I do remember the stuff about squaring and re-normalizing) Consequently, I cannot figure out what you mean by; Thank you -Anssi |
| Sep14-07, 09:31 AM | #529 |
Mentor
I'm afraid that this thread has been allowed to remain in violation of the guidelines on personal theories for too long.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Is time just an illusion?
| Time: An illusion? | General Discussion | 7 | ||
| Is mass an illusion? | General Discussion | 8 | ||
| Is Life an Illusion? | General Discussion | 12 | ||
| Is Simultaneity an Illusion? | General Physics | 32 | ||
| Help.... (illusion) | General Discussion | 5 | ||
