Thread Closed
Distances between Atoms in a Gas Molecule
Share Thread
Jul31-06, 09:40 PM   #1
How do you calculate the distances between atoms of a given gas molecule? The reason im asking this is so I can find the moment of inertia of certain molecules so i can determine degrees of freedom for a gas at a certain temperature. Is there an easier way to determine them?
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Jul31-06, 09:55 PM   #2
Recognitions:
Gold Membership Gold Member
Quote by dingsbunnyranch
can't gas expand and compress? Wouldn't this imply that there is no absolute distance between atoms in a gas, and that its relative to the pressure and volume?
Just using logic, with no advanced physics training (i'm just starting my third year as a physics undergrad), I'd guess that you could use the ideal gas law:
PV = nRT where P is Pressure, V is volume, n is number of moles, R is the gas constant, and T is the temperature.
you could find out the volume per atom (V/n = RT/P) and derive it from there, i suppose. But I think gases rely on fluid dynamics, which are really complex, and the distance between atoms will be different for different localities within a given 'cloud' of gas.
Aug1-06, 05:17 AM   #3
Recognitions:
Retired Staff Staff Emeritus
Pythagorean, I think you misunderstood the question. The question was not about the distance between molecules (atoms) in a gas but about the distance between atoms in a single molecule.
I don't see any simple way to answer that- it depends on the type of gas. You might be able to look up distance between atoms for a particular molecule in something like the CRC tables.
Aug1-06, 01:18 PM   #4
Recognitions:
Quote by HallsofIvy
ah, yes, I see. I think this is a common study in chemistry.
from wikipedia:
This weak attraction takes place already at long distances of 100 nanometer, whereas the stronger repulsion only becomes preponderant at distances of 100 picometer, a distance which is similar to atomic radii. The atoms are held together at the distance at which the attractive and repulsive forces cancel out.
The length of a chemical bond is taken to be the average distance between the two nuclei. For gases it can be determined to a high degree of accuracy by rotational spectroscopy or by electron diffraction. For solids, it is usually measured by X-ray diffraction: however this method cannot measure the length of bonds involving hydrogen, for which neutron diffraction must be used. Average bond lengths (often with standard deviations) for a large number of bond situations in inorganic and organic compounds have been calculated from data in the Cambridge Crystallographic Database. Other factors being equal, a shorter bond is also a stronger bond.
http://en.wikipedia.org/wiki/Chemical_bond/Temp
Thread Closed
Similar discussions for: Distances between Atoms in a Gas Molecule
Thread Forum Replies
Assume that on earth we see something 1 billion light years away General Astronomy 7
vdw distances Biology, Chemistry & Other Homework 2
Determing distances on the fly General Astronomy 3
Distances General Astronomy 7
distances Introductory Physics Homework 3
