| Thread Closed |
Question Regarding Goldbach's Conjecture |
Share Thread | Thread Tools |
| Aug9-06, 01:36 PM | #1 |
1*1
1*3 2*2 3*1 1*5 2*4 3*3 4*2 5*1 1*7 2*6 3*5 4*4 5*3 6*2 7*1 * * * etc. If we go on constructing the pattern of numbers above, will each row contain atleast 1 product of two odd prime numbers? If the answer to this can be proven to be yes, then would this prove also Goldbach’s conjecture considering the fact that the sum of any numbers in a row adds up to twice the square root of the perfect square of that row, and that all even numbers greater then 4 are accounted for in the matrix? For example, in the row that contains the perfect square 2*2, we have 3+1 = 4, with 3 and 1 odd prime numbers. In the row containing the perfect square 3*3 we have 5+1 = 6, with 5 and 1 odd prime numbers…etc. Might this be related to Goldbach’s conjecture? Inquisitively, Edwin G. Schasteen |
| Aug9-06, 01:55 PM | #2 |
Recognitions:
That's the same as goldbach, rather trivially. Goldbach just asks if for any integer n if one of the pairs (2,2n-2), (3,2n-3), ... (n,n) is made up of two primes (yours is actually just slightly weaker, and considers (1,2n-1) as well, which won't help goldbach). It's no easier (actually probably harder) to determine if (k)*(2n-k) is a product of two primes than it is to determine if k and 2n-k are both prime on their own (this is assuming you don't know the factors of (k)*(2n-k) on hand, if you do it's equivalent).
| Aug9-06, 07:09 PM | #4 |
Oh yea, one isn't prime, I overlooked that.
Code:
(yours is actually just slightly weaker, and considers (1,2n-1) as well, which won't help goldbach). It's no easier (actually probably harder) to determine if (k)*(2n-k) is a product of two primes than it is to determine if k and 2n-k are both prime on their own Inquisitively, Edwin |
| Aug9-06, 07:14 PM | #5 |
Recognitions:
No, they are equivalent. Solve one and you solve the other. The thing is that as stated your version of the problem is going to be harder to prove.
| Aug23-06, 01:07 PM | #6 |
In fact..didn't Vinogradov gave the "exact" formula explaining the way in which an Odd number could be represented as the sum of 3 primes:
[tex] I(N)= \int_{0}^{1}dx( \sum_{p<N}e^{2i p \pi x})^{3}e^{-2i \pi Nx } [/tex] of course we could use some "lower bound" for the prime number counting function to calculate the sum over primes inside the integral. |
| Aug23-06, 05:17 PM | #7 |
Recognitions:
| Aug23-06, 05:53 PM | #8 |
Recognitions:
[tex]\pi(x)>\frac{x}{\ln x}\left(1+\frac{1}{\ln x}+\frac{1.8}{\ln^2x}\right)[/tex] for x >= 32299. |
| Aug24-06, 04:58 AM | #9 |
Sorry..i didn't know if was vinogradov or other who gave that formula for I(N).. the formul is exact but the problem is that you need to evaluate a sum over primes of the exponential i think that :
[tex] \sum_{p<N} e^{2i p \pi x} \sim \int_{2}^{N} dt \frac{e^{2i \pi t}{log(t)} [/tex] for big N.. in that case you could prove that any N N-->oo can be expressed as the sum of 3 primes. By the way..could someone indicate me where could i find "circle method" approach to the Goldbach conjecture?..thanks. |
| Aug24-06, 05:20 AM | #10 |
Recognitions:
Jose, could you please write one post where you don't say 'we could' and then write something you totally fail to justify as a valid method of attack on a problem? (Not sure whatt the latex code is supposed to be).
| Aug24-06, 09:08 AM | #11 |
Recognitions:
| Aug24-06, 06:02 PM | #12 |
Recognitions:
| Aug24-06, 06:25 PM | #13 |
Recognitions:
| Aug25-06, 12:42 AM | #14 |
Recognitions:
It appears that the left side is the sum of one raised to the power of x * p. |
| Aug25-06, 12:51 AM | #15 |
Recognitions:
| Aug25-06, 02:32 AM | #16 |
Then we could try with the "best" known possible lower boun for the prime number counting function:
[tex] \pi(x) >Ag(x) [/tex] g(x) is a known function and A a real constant (of course i don't know much about the upper and lower bounds for the prime number counting function) in that case we have that: [tex] \sum_{p<N}e^{2i \pi px} > \sum_{k=2}^{N}[g(k)-g(k-1)]e^{2i \pi kx} [/tex] then insert the sum on the left and get I(N) of course if we had that the integral: [tex] \int_{0}^{1}dx(\sum_{k=2}^{N}[g(k)-g(k-1)]e^{2i \pi kx})^{3} e^{-2i \pi N}=\int_{0}^{1}dx e^{-2 \pi N x}\int_{2}^{N}e^{2i \pi xt}g'(t)dt >0 [/tex] then Goldbach conjecture would be true....if this isn't possible then we should look another way to prove it. |
| Aug25-06, 02:35 AM | #17 |
Recognitions:
| Thread Closed |
| Thread Tools | |
Similar Threads for: Question Regarding Goldbach's Conjecture
| Goldbach's Conjecture (Theorem??) | Linear & Abstract Algebra | 38 | ||
| BKL Conjecture | Special & General Relativity | 0 | ||
| Collatz conjecture question | General Math | 1 | ||
| Goldbach's Conjecture | General Math | 2 | ||
| Proof of Golbach's conjecture and the twin prime conjecture | Linear & Abstract Algebra | 9 | ||
