Meridian Electronics - Circuit Question: 10k Resistor
  • Thread starter Thread starter david90
    Circuit
The discussion centers on the configuration of a 10k resistor in a circuit involving a potentiometer. It clarifies that the 10k resistor is connected to a 56k resistor and ground, with an arrow indicating a connection to a 100 µF capacitor. The presence of three connections on the resistor confirms its identity as a potentiometer, commonly used to adjust voltage levels, similar to a volume control in audio devices.
  • Basic understanding of electronic components, specifically resistors and capacitors.
  • Knowledge of potentiometers and their function in circuits.
  • Familiarity with circuit diagrams and schematic symbols.
  • Experience with reading and interpreting electronic schematics.
  • Research the function and applications of potentiometers in electronic circuits.
  • Learn about the role of capacitors, specifically 100 µF capacitors, in filtering and timing applications.
  • Explore circuit design principles involving resistors in series and parallel configurations.
  • Study common circuit analysis techniques to better understand component interactions.
Electronics enthusiasts, hobbyists, and students studying circuit design and analysis will benefit from this discussion, particularly those interested in the practical applications of resistors and potentiometers in electronic devices.
david90
go to http://www.meridianelectronics.ca/circ/batmon12.htm.
the 10k resistor is connected to the 56k resistor and ground but what is that arrow that goes from 100 uf to the 10k? This resistor has 3 connections?
its a pot (potentiometer). With such device you turn the "volume" wheel for eg.
  • · Replies 19 ·
  • · Replies 16 ·
