Finding the Zero Net Electric Field Point for Two Point Charges on the x-axis
  • Thread starter Thread starter keeganisafish
The problem involves determining the point along the x-axis where the net electric field from two point charges, +10nC and -20nC, is zero. The charges are positioned at x=0 and x=+10m, respectively. There is some confusion regarding the correct location of this point, with differing opinions on whether it is at 24m or 20m.
  • Exploratory, Assumption checking
  • Participants discuss their calculations and reasoning for finding the zero net electric field point, with one participant asserting that the correct answer is 24m while another believes it to be 20m. There is mention of using the electric field equations for both charges and setting them equal to zero to find the point of interest.
The discussion is ongoing, with participants sharing their calculations and questioning each other's reasoning. Some guidance has been offered regarding the setup of the equations, but there is no clear consensus on the correct answer yet.
Participants are working under the constraints of a homework assignment, which may influence their approaches and the assumptions they make about the problem setup.
keeganisafish
I really need help, and I'd greatly appreciate it.
"Two point charges of +10nC and -20nC lie on the x-axis at points x=0 and x=+10m, respectavly. Find the point where the net electric field is zero, if such a point exists."
The teacher gave us the answer 24m, and I just can't see how!
You help is REALLY APPRECIATED, I have been on this one forver it seems...
I keep getting 20m?
Show your solution sheet where u got 20 m
24m is correct
I did
k*10nC     k(-20nC)
(10m)^2     (d-10m)^2
And solved for d
Originally posted by keeganisafish
I did
k*10nC     k(-20nC)
(10m)^2     (d-10m)^2
And solved for d
It should be
[tex]\frac{k*10nC}{r^2}-\frac{k*20nC}{(10+r)^2}=0[/tex]
coz fields adds upto zero on the position left to origin
i should say for x=-24
thanks!
  • · Replies 68 ·
9K
