Column Problem Help: Calculating Length of Conical Steel Column Under Load
  • Thread starter Thread starter teng125
    Column
The discussion focuses on calculating the deformed length of a conical steel column under a normal axial load of 1450 kN. The column has an original length of 1000 mm, a head diameter of 90 mm, and a ground diameter of 190 mm. The correct approach involves integrating the strain along the length of the column, using the formula (F/E) ln[(π*d^2)/4] to determine the change in length. The integration must account for the varying diameter along the column's length.
  • Understanding of axial load and its effects on structural members
  • Familiarity with material properties, specifically Young's modulus (E)
  • Knowledge of calculus, particularly integration techniques
  • Concept of strain and its relationship to deformation
  • Study the mechanics of materials, focusing on axial loading and deformation
  • Learn about the derivation and application of the hollow cylinder formula in structural analysis
  • Explore advanced integration techniques for varying cross-sectional areas
  • Investigate the properties of conical structures in engineering design
Structural engineers, mechanical engineers, and students studying mechanics of materials who are involved in the analysis and design of load-bearing columns.
teng125
A straight conical column made of steal (original length 1000mm, head diameter 90 mm, ground diameter 190 mm) is loaded by a normal force F = 1450 kN. What is the length under load ?
for this ,the diameter is changing along the column,should i assume is as hollow and use the hollow formula for the area or any other ways??
i get (force/E) (1/A(x)) dx = d(strain)
then i integrate to get (F/E) ln[(pi*d^2)/4] = deformed length - original lengh
am i correct??
When you say normal force, what do you mean? Axial or normal to the member? If it is axial, then yes, you have to integrate.
12K
  • · Replies 19 ·
13K
10K
11K
