Thread Closed
Chain Rule/Product Rule Question
Share Thread Thread Tools
Aug17-06, 10:40 AM   #1
I am suppose to derive the following and then find x if f´(x)= 0
f(x) = (6-x2) [tex]\bullet[/tex] e2x
Which one should be used? I guess I am confused with the fact that it is e2x
Product rule gives:
(6-x2) [tex]\bullet[/tex] e2x + e2x [tex]\bullet[/tex] (-2x)
e2x(6-x2-2x) (x1 = 0)
-x2-2x+6 = 0 gives decimal values that doesn't seem to fit.
Chain rule gives:
I'm not even sure how to start here. I assume that the outer derivate is e2x? Or should the chain rule be applied to it and then the product rule?
Some kind of hint as to what is the correct path would be greatly appreciated
Edit: Latex mishap >_>
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Aug17-06, 10:54 AM   #2
Recognitions:
Homework Helper Homework Help
I assume that the big, big dot in your post is the multiple sign.
You can use both rules (i.e, Chain Rule, and Product Rule) in this problem. There's no limit of the number of the rules you can use. So, just use it where you think is appropriated.
f(x) = (6 - x2) e2x
f'(x) = (6 - x2)' e2x + (6 - x2) (e2x)' = ...
You have taken the derivative of e2x with respect to x incorrectly.
We should use the Chain Rule there. By letting u = 2x, we have:
[tex]\frac{d}{dx} e ^ {2x} = \frac{d (e ^ u)}{du} \times \frac{du}{dx} = \frac{d(e ^ u)}{du} \times \frac{d(2x)}{dx} = ...[/tex]
So, can you see where your mistake is?
Can you go from here? :)
Aug17-06, 12:15 PM   #3
Of course.
The inner is 2.
2e2x(6-x2)+ e2x(-2x)
e2x(12-2x2)+ e2x(-2x)
12-2x2-2x = 0
and there we have the values of x.
Thank you VietDao29, you were very helpful
Thread Closed
Thread Tools
Similar Threads for: Chain Rule/Product Rule Question
Thread Forum Replies
Chain Rule vs Product Rule Calculus & Beyond Homework 1
product and chain rule Calculus & Beyond Homework 2
Chain/Product rule Calculus & Beyond Homework 2
Product and Chain Rule Calculus 8
combining product rule with chain rule Calculus 2
