Project to detect open collector/ high impedance signals
The discussion centers around a project aimed at monitoring an open collector alarm signal, which is high impedance when not active. Participants explore methods to connect this signal to a computer for logging alarms, including circuit design and software options.
  • Technical explanation, Experimental/applied, Debate/contested
  • One participant seeks assistance in monitoring an open collector signal from an alarm device and logging it on a computer.
  • Another participant suggests using a pull-up resistor and connecting the signal through a computer's parallel port as a straightforward solution.
  • A follow-up inquiry requests specific circuit designs, pin assignments for the parallel port, and software recommendations for monitoring alarms.
  • Concerns are raised about regulatory requirements for alarm systems, although one participant clarifies that their project does not involve a commercial building and thus is not subject to such regulations.
  • Further advice is given to search online for schematics and software related to interfacing TTL-level signals, with a recommendation to use a 5V pull-up resistor.
Participants express differing views on the necessity of regulatory compliance for alarm systems, with some emphasizing the importance of regulations while others assert that their specific project does not require adherence to such rules. The discussion regarding circuit design and software remains open-ended, with no consensus reached on specific solutions.
Participants mention the need for detailed setup information and appropriate software, indicating that there may be missing assumptions or dependencies on specific hardware configurations.
dforde
I am trying to come up with a way to monitor a device that alarms. The signal is open collector: high impedance when not alarm. I would also like to be able to connect this to a computer and monitor and log the alarms when they happen. Any help would be greatly appreciated.
Use a pull-up resistor. You can connect a TTL-level signal through your computer's parallel port. (This is the easiest way, at least.)
- Warren
Thanks for the reply, do you know of an available circuit design for this, and the pin assignments for the port, also what kind of software could I use for the monitoring of the alarms, any and all help is greatly appreciated, the commercial solution to this is very $$$$$$.
I understand the desire to save money, but aren't there regulations governing alarm systems? In my experience, there are certain things that need to be done in a certain way, in order for a commercial building's insurance underwriter to approve of an alarm system.
This project is not for a building or anything like that, so there are no regulations involved, I have a number of alarm devices that when they alarm, there is a 3.5mm mono jack, tip is signal output, ring is 0V. Signal is open collector type: high impedance when not alarm, low. I want to be able to monitor the devices on a single computer, so I can log when they go off. Any help for a solution to this is appreciated, I am also trying to keep cost to a minimum. The pull-up resistor idea might work if I can get details on the setup, and appropriate software to monitor it.
Schematics (and software) for interfacing TTL-level signals are all over the web -- try using google to search for them. Use a 5V pull-up resistor, and you should be fine.
- Warren
  • · Replies 20 ·
  • · Replies 47 ·
  • · Replies 33 ·
