"fully developed laminar flow" and fully developed turbulent flow"?
The discussion revolves around the differences between fully developed laminar flow and fully developed turbulent flow, exploring the conditions under which these flow types occur, particularly in various fluid dynamics scenarios such as flow through channels and over plates. Participants delve into the characteristics, definitions, and implications of fully developed flow in both laminar and turbulent regimes.
  • Some participants describe laminar flow as having stable and smooth trajectories, while turbulent flow is characterized by chaotic and unstable trajectories.
  • There is a suggestion that fully developed flow implies a non-changing velocity profile, with laminar flow exhibiting a parabolic profile and turbulent flow resembling a rectangular shape.
  • Participants discuss the Reynolds number (Re) as a critical factor in determining whether flow is laminar or turbulent, with some asserting that the transition to turbulence may also depend on other scaling parameters like the Richardson number and the Rossby number.
  • One participant raises the question of whether fully developed flow can exist in channels formed by S-shaped fins, considering different working fluids and their respective Reynolds numbers.
  • Another participant explains that a fully developed velocity profile means that its derivative with respect to the streamwise coordinate is zero, and discusses the conditions under which this can be achieved in periodic configurations.
  • There is a query about the existence of fully developed turbulent flow over a plate, with some asserting that it is possible, while others argue that the boundary layer continues to develop and does not reach a constant value.
  • One participant emphasizes that "fully developed" flow terminology is typically applied to pipe or channel flows and may not be applicable to external flows like those over a flat plate.
Participants express differing views on the applicability of the concept of fully developed flow to external flows, particularly over plates. While some assert that it is possible, others argue that the boundary layer characteristics indicate that the flow does not achieve a fully developed state in this context. Overall, the discussion remains unresolved regarding the conditions under which fully developed flow can be defined in various scenarios.
Participants note that the definitions and conditions for fully developed flow may depend on specific configurations and assumptions, such as the geometry of the flow channel and the characteristics of the working fluid. The discussion highlights the complexity of flow behavior and the influence of various parameters on flow development.
miffy1279
Hi all,
can you tell me what different between "fully developed laminar flow" and fully developed turbulent flow"? :cry:
miffy1279 said:
Hi all,
A vague question. There are entire books written on each of those two types. To say something, the laminar flow is a flow where the fluid particles make a stable and smooth trajectories. Laminar flows can be stable or unstable flows. On the contrary, a turbulent flow is a flow where the fluid particles make instable and non smooth trajectories. The turbulent flow has a chaotic behavior built-in caused by the inertial instability.
FredGarvin said:
Perhaps take a quick peek here:
https://www.physicsforums.com/showthread.php?t=92823
It could be that the OP was looking for something simple like a fully developed flow means a non changing velocity profile. The laminar profile is parabolic and the turbulent is essentially rectangular(ish).
http://www.tpub.com/content/doe/h1012v3/img/h1012v3_40_1.jpg
Thank you guys,
Let consider the channels formed by S-shaped fins, as shown in the link.
"[URL
- A supercritical CO2 as working fluid flows inside these channels with Re ~ 10000. Do you think a fully developed turbulent flow exist?
- A water as working fluid flows inside these with Re ~ 1000. Do you think it is the Fully developed laminar flow?
miffy1279 said:
Thank you guys,
"[URL
The character of turbulent or laminar regime DOES NOT depend on the substance, but on the scaling parameter Re--->>> we don't care what is going on with the fluid. With that I mean that your pipe configuration should have a tested critical Re for reaching the turbulent regime, that Re is universal, and I bet it is lower than the critical Re for a single pipe (which is around 2000, isn't it Fred?).
EDIT: well, the transition to turbulence >may< depend on another scaling parameters, not only on the Reynolds, but also on the Richardson number as in the case of a buoyant flow, or on the Rosby number as in the case of a rotating system (The Earth). These three mechanisms (viscosity, buoyancy, and coriolis forces) are the main generators of uncontrolled vorticity eventually leading to turbulence.
Thank you Clausius2,
But how about fully developed flow? Can it exist in such flow channel configuration?
Let's talk about fully developed flow. A fully developed velocity profile is such that its derivative respect to the streamwise coordinate is zero. In turbulent flow it is said that a profile is fully developed when its statistics does not depend on the streamwise coordinate. I mean, the mean velocity profile does not depend on the streamwise coordinate, is the same in every section. Looking at your thing, I saw a periodic configuration, with sudden expansions and bifurcations. Well, just after the hidrodynamic entrance length, which is the length spend by the fluid for acquiring the fully developed profile, you can assume you have a fully developed profile. For calculating your an estimation of the hydrodynamic entrance length you can use [tex]L_e\sim R\cdot Re_R[/tex] where R is the radious of your small fin interstice, and Re_R is the reynolds based on the radius. Imagine that [tex]L[/tex] is the length of each one of those small tubes formes by the fins and which are periodic in the space. If [tex]L<<L_e[/tex] then the flow is never fully developed there. If [tex]L>>L_e[/tex] which would happen in your case only if [tex]R<<L/Re[/tex], then you have the chance of getting a fully developed flow after the hydrodynamic length.
Does it makes sense now?.
fully developed turbulent flow over plate
Is it possible to have a “fully developed turbulent flow” over plate?
I am interested is incompressible subsonic flow and I know that the fully developed turbulent flow, i.e., constant velocity profile can happen inside pipes or channels or between two parallel plates.
Does the boundary layer of turbulent flow over plate reach a constant value?
If so how are boundary layer displacement and boundary layer displacement thickness obtained?
Thanks
Yes. Only variable here is the Reynolds' number.
Incompressible flow means rho=const, which is a good approximation for Mach<0.3~0.4. If incompressibility is waived as a simplification, you may have subsonic, etc. Note that the supersonic/subsonic is generally defined locally, or for areas of flow.
No. it continues to develop in the direction of the flow.
They are both defined locally, and if x is the coordinate in the direction of the flow, they're function of x.
Cheers
You responded that it is possible to have a “fully developed turbulent flow over a single plate” and the only variable here is the Reynolds' number.
I am interested in FULLY DEVELOPED, which means its velocity profile does not depend on the streamwise coordinate.
I would like to know if it really happens over a single plate and if I can assume that its statistics does not depend on the streamwise coordinate
Thanks
No fully developed external flow
The boundary layer thickness generally grows in the direction of the flow, and the flat plate is no exception. Thus, the velocity profile in the boundary layer will change streamwise; it is just this chage is much smaller than in the direction normal to the plate (within the boundary layer).
"Fully developed" flow is pipe/duct/channel flow terminology, and doesn't really apply to external flows. Nevertheless (and especially for flat plate), boundary layer thickness (dispalcement thickness, etc) can be thought as a function of Re_x=U*x/niu, where x is the streamwise distance to the leading edge.
Thanks
Within the boundary layer, you can assume that variation of turbulent stresses in streamwise direction is much smaller than that in the normal direction, i.e. d[ui'*uj']/dx << d[ui'*uj']>/dym, but it is inaccurate to say that they don't change at all.
Cheers. // Rope
  • · Replies 0 ·
  • · Replies 20 ·
  • · Replies 31 ·
