Angular momentum without rotational energy?
In summary, angular momentum without rotational kinetic energy?A particle with angular momentum has that momentum about a certain reference point in space. However, you don't need rotational or circular motion of any kind to have nonzero angular momentum about some point. This is demonstrated by the example of a free particle moving in a straight line. Additionally, angular momentum can be expressed as L=r x p, where r is the radius of the circle and p is the magnitude of the angular momentum. However, angular velocity and moment of inertia must exist, which contradicts what we originally stated.
mfactor
Angular momentum without rotational kinetic energy?
Consider a particle (a ball or electron or whatever you like) that moves in a perfect circle with constant angular and tangential velocity about a fixed point in space. This particle does not spin about itself. The movement is perfectly translational. (OR could we say its movement is rotational?)
Obviously, this particle has angular momentum about this fixed point. Also, this particle has translational kinetic energy. However, could we say that this particle has rotational kinetic energy?
I will not answer your questions officially as I don't recall even seeing a formal definition of the terms "rotation" and "rotationnal energy". Unoficially, however, I can casually say that yes, I would use the words "the particle is in rotation about that point" to describe the motion. And I would say that its kinetic energy is of rotational nature.
I mainly wanted to reply to your post in response of its title, "Angular momentum without rotational energy?" to show you a trivial exemple in which "Angular momentum without rotational energy!"
Consider a free particle of mass m moving in a straight line at unit velocity. Suppose we take a coordinate system in which its motion is given by (x(t)=t, y(t)=1, z(t)=0). The angular momentum of the particle about the origin is [itex]L=|\vec{r}\times \vec{p}|=mrsin\theta = mr(1/r)=m[/itex]
There is no rotational motion whatesoever, yet, L is not zero. So, you see that angular momentum doesn't have that much to do with rotation. I had this prejudged about angular momentum at a time and this exemple "opened my eyes" so to speak, so now I pass it on to whoever may read this. Amen.
As quasar987 explained, you don't need rotational or circular motion of any kind to have non-zero angular momentum about some point. (I would have given the same example.)
The total KE of an (extended) object can be viewed as the sum of the translational KE of the center of mass plus the rotational KE about the center of mass. So, in that sense, the circularly moving (revolving, but not rotating) object in your example has pure translational KE.
But don't get hung up on semantics.
Either way of calculating the KE ([tex]0.5I\omega ^2~or~ 0.5mv^2 [/tex]) gives you the same answer. So I guess it doesn't matter what you call it. Typically though, "translation" is used to describe linear displacements.
I meant rotational kinetic energy. Pardon my omission of the word "kinetic"
I edited the title of this thread to include "kinetic"
Yes, I had understood that even an object moving in a straight line has an angular momentum with respect to a certain point.
The red portion was what I thought it was. Yes, the object is "revolving" but not "rotating," hence no rotational kinetic energy. Revolving is just another case of translation, so the object has translational kinetic energy.
So far, I had no confusion. But hereforth, my confusion starts.
Consider a straight-moving particle. It has angular momentum about a certain reference point in space. Obviously, this particles angular monentum about the reference point is L= r x p
But also, Angular momentum can be expressed as [itex]L = I \omega[/itex]
Since angular momentum exists, angular velocity ([itex]\omega[/itex]) and moment of inertia (I) must exist. Since both exists, the rotational kinetic energy KE_r =0.5 Iw^2 must exist. This is contradictory to what we have first stated.
Angular velocity in this case is easy to imagine. I just think of a line stretching from the reference point to the particle and imagine how much radian this line moves in a very short period of time.
But moment of inertia...hmm...? This momen of inertia is NOT the moment of inertia of the particle that occurs when the particle spins about its center of mass. Then what are we thinking here?
A discrete mass cannot rotate about a point. There has to be matter at the centre providing the centripetal force.
I don't see a problem with saying that the mass has rotational kinetic energy with respect to the frame of reference of the centre of rotation. After all, the difference between that and a spinning hoop is just that the mass in the hoop is spread out.
AM
It's a matter of semantics. The object certainly has no rotational KE about its center of mass, which is what counts. Whether you treat the object as a whole as simply translating or as "rotating" about a point is up to you.
No problem.
I see your point, but I'd still call it semantics.
It's the moment of inertia of a point mass about some reference point. In your example of a particle in circular motion you have two choices for calculating the KE. You can express it in terms of linear speed as: KE = 0.5 m v^2; or in terms of angular speed as: KE = 0.5 I w^2. Of course I for a point mass about the center of the circle is just: I = mR^2. Since v = wR, KE = 0.5 I w^2 = 0.5 m v^2. You get the same KE either way you slice it!
Thanks. I got it.
1. What is angular momentum?
Angular momentum is a property of a rotating object that determines its resistance to changes in its rotation. It is the product of an object's mass, velocity, and distance from its axis of rotation.
2. How is angular momentum related to rotational energy?
Angular momentum and rotational energy are related through the concept of conservation of angular momentum. This means that in a closed system, the total angular momentum remains constant, even if there are changes in rotational energy.
3. Can an object have angular momentum without rotational energy?
Yes, an object can have angular momentum without rotational energy if its axis of rotation is perpendicular to its momentum. This is known as translational angular momentum.
4. What are some real-life examples of angular momentum without rotational energy?
One example is a spinning top. When it is spinning on its tip, it has angular momentum without any rotational energy. Another example is a planet orbiting around its axis. The planet has angular momentum due to its orbit, but its rotational energy is zero since it does not rotate around its own axis.
5. How is angular momentum without rotational energy important in physics?
Angular momentum without rotational energy is important in explaining the motion of objects in space, such as planets and galaxies. It also helps us understand the behavior of spinning objects, like tops and gyroscopes. Additionally, it is a fundamental concept in quantum mechanics and is used in many technological applications, such as MRI machines and satellites.
