Thread Closed
Calculating Electric Potential in A Uniform Electric Field
Share Thread
Jan21-04, 03:47 AM   #1
Here's the problem:
Two points are in an E-field: Point 1 is at (x1,y1) = (4,4) in m, and Point 2 is at (x2,y2) = (13,13) in m. The Electric Field is constant, with a magnitude of 65 V/m, and is directed parallel to the +x-axis. The potential at point 1 is 1000 V. Calculate the potential at point 2.
IT IS ABSOLUTELY SICKENING How Many Times I Attempted this Seemingly Easy Problem And Got it WRONG...so apparently, this isn't as easy as I thought !
I KNOW this problem Has to utilize the formula V = Ed (or perhaps V = Edcos(theta) ???)
for d i get sqrt((13-4)^2 + (13-4)^2) = 12.7279
and E is given
soooooooooo... for the change in potential i get 827. I then add that to the potential of point 1 to get the potential of point 2 and I get 1827. But apparently that's wrong. So are the answers 1000, 1585, and 1292 which I got from slightly tweaking the main formula in different ways. I have no clue what else to try...any help ?
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Jan21-04, 05:43 AM   #2
First of All look at the direction of Electric field it is in +x direction So Potential is going to decrease in +x direction
Moreover Apply
[tex]E\cos(45)^0r=|\Delta V|[/tex]
Jan21-04, 07:13 AM   #3
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
himanshu121: Do you really need to worry about the angle? Since the Field is directed in the x-direction, the potential only changes in that direction. For a constant field intensity, F, the change in potential is F times the change in x coordinate. In this problem the x coordinate changes from 4m to 13m (a change of 13-4= 9m) and F= 65 V/m so the change in potential is 65 V/m * 9 m= 585 V. As himansh121 pointed out, this is a decrease so it is -585 volts. Now, you know the potential at (4,4) so what is the potential at (13,13)?
Jan21-04, 08:31 AM   #4
Yup, rcos45=13-4, I got ur reply Halls
the equipotential surface is a planar surface hence it would be same for x=c which is || yz[:))]
Jan21-04, 07:07 PM   #5
AHHHHHHHHHHHHHHHHH so my main problem was the sign... lol dang I gotta becareful of that, thanks.. and thanks himanshu
Thread Closed
Similar discussions for: Calculating Electric Potential in A Uniform Electric Field
Thread Forum Replies
Potential difference, uniform electric field Introductory Physics Homework 1
Calculating the Electric Potential from an Electric Field problem Introductory Physics Homework 1
Potential Differences in a Uniform Electric Field Introductory Physics Homework 3
Zero Potential In Uniform Electric Field Introductory Physics Homework 3
electric potential in a uniform electric field...please help Introductory Physics Homework 1
