| Thread Closed |
Electromagnet help please? |
Share Thread | Thread Tools |
| Aug30-06, 07:26 AM | #1 |
Electromagnet help please? HI EVEYONE, NEED TO TAALK TO SOMEONE WHO IS UP ON CALCULATING THE VALUE OF (B), REQUIRED TO LIFT A PLATE OF XXNEWTONS. ALSO ESTIMATE THE M.M.F REQUIREDTO LIFT THE SAME PLATE. ANY TAKERS PLEASE? THANKS |
| Aug30-06, 10:45 AM | #2 |
Mentor
No need to yell. What are the equations that describe the force generated by current flowing in a coil?
| Aug30-06, 02:46 PM | #3 |
I WILL TRY EXPLAIN MY QUESTION AND PRESENT YOU WITH ALL THE FACTS I HAVE AT MY DISPOSAL.
In the question it is first mentioned that the pull,P, exerted at each pole of the magnet is given by the equation: P = Bsquared x A divided by 2 x permeability of free space. A being CSA of the pole faces free space being 4 x pie x 10 to power of -7. OK. next we have c.s.a of magnet: 22 x 22 cm. R, radius: 0.5m. angle in degree`s: 120. relative permeability of magnet: 2000. relative permeability of plate: 1000. thickness of plate: 5cm weight of plate: 10'000 Newtons. I have drawn out a diagram to show you what the radius and angle are all about. Can i paste a paint document here? It would help a lot. Many thanks . |
| Aug30-06, 03:18 PM | #4 |
just save the the jpeg file on your computer and then attach it to the post.
| Aug31-06, 09:02 AM | #5 |
electromagnet question.doc
Q1, I need to calculate the value of B required to lift a plate. Q2, Estimate the mmf F required to lift the same plate. I understand P = B squared x A. divided by 2 x permeability of free space. This is what I have to work with: The plate to be lifted weighs, 10`000 Newtons Relative permeability of plate, 1000 Thickness of plate, 5 cm. c.s.a. of magnet, 22 x 22 cm. radius (mean) of magnet, 0.5m ( shown as red circle) angle in degrees, 120. I am assuming you have to first calculate the distance between the 2 poles. Using the cosine rule I make it: 0.75metres. Now I need help with the rest please. I don’t just want the answer I want to understand the formula properly. Many thanks. |
| Sep3-06, 11:49 PM | #6 |
Can you define more clearly, the units for each of the variables in your expression
[tex]P = \frac{B^2 A}{2 \mu_o}[/tex] by the way, your expression looks similar to one I note on this page. Are you using the same units? From your given information, I don't see a value for "magnetic flux density" B. Perhaps you have some given information from which you can derive B. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Electromagnet help please?
| DC electromagnet | Electrical Engineering | 16 | ||
| Small Electromagnet | Electrical Engineering | 1 | ||
| Hello, I am currently planning on constructing an electromagnet. | Computing & Technology | 3 | ||
| Electromagnet problem | Electrical Engineering | 7 | ||
