Finding Absolute Extreme Values of f(x)=2x^3-3x^2-12x+1 [-2,3]
  • Thread starter Thread starter Sethka
    Value
The discussion revolves around finding the absolute extreme values of the function f(x) = 2x^3 - 3x^2 - 12x + 1 over the interval [-2, 3]. The original poster seeks to apply the extreme value theorem to determine these values.
  • Exploratory, Conceptual clarification, Problem interpretation
  • The original poster attempts to apply the extreme value theorem and has calculated the derivative of the function, identifying critical points at x = 2 and x = -1. Some participants clarify the role of the extreme value theorem and discuss the importance of evaluating the function at critical points and endpoints to find absolute extrema.
The discussion is progressing with participants providing clarifications about the extreme value theorem and the process of evaluating the function at specific points. There is an acknowledgment of the need to evaluate f(x) at the identified critical points and endpoints to determine the absolute maximum and minimum values.
Participants note that the function is continuous on the closed interval, which is a requirement for the extreme value theorem to apply. There is also mention of critical points where the derivative does not exist, which could be relevant for identifying extrema.
Sethka
Hey guys,
I need to use the extreme value theorem to find the absolute extreme values of this function.
So far, I've got:
f'(x)=6x^2-6x-12=6(x^2-x-2)=6(x-2)(x+1)
x= 2,-1
Now what do I do? Please explain in a manner a non-math student can comprehend please.
Thank you!
Hi Sethka,
The extreme value theorem isn't used to find absolute extrema, rather it tells us that they exist for certain kinds of functions. More specifically it says that continuous functions defined on a closed interval have absolute extrema, but doesn't tell us anything about where they might be. Your function is continuous, as all polynomials are, and is defined on the closed interval [-2,3], so the extreme value theorem guarantees the existence of absolute extrema. This is important, cause you don't want to go and try and find extrema if there aren't any.
Ok, back to the problem. You have found the roots of the derivative of f, ie: values of x for which f'(x) = 0. These along with the endpoints of the interval [-2, 3] are the possible locations for the absolute extrema. What you do now is plug these points into f(x) and find which one makes f(x) the largest and the smallest. Those values of x are the locations of your maxima and minima respectively.
So in short your going to evaluate f(-1), f(2), f(-2), f(3). The largest of these is the absolute maximum, and the smallest is the minimum.
Thanks!
Oh Wow Nocturnal! You've just helped me make sense of something I never really understood for the last two months! You're awesome! Thanks! My textbook sounds belligerent on the topic, so I skipped it and just never really learned it all this time.
Your welcome. You should also be aware that points in the domain of f, where f'(x) doesn't exist are also candidates for locations of extrema. Together all these points are referred to as "the critical numbers of f."
  • · Replies 25 ·
  • · Replies 18 ·
