How Does a Glass Block Affect the Convergence Point of Light Rays?
The discussion revolves around the behavior of light rays as they pass through a rectangular block of glass placed in front of a screen. The original poster is trying to determine the new convergence point of the rays after encountering the glass block, considering the nature of refraction and the properties of the glass compared to a lens.
  • Participants explore the effects of the glass block on the convergence of light rays, questioning whether the rays would still converge on the screen or if they would be displaced. The original poster expresses confusion about the behavior of the rays and the implications of using a glass block instead of a lens.
Some participants have offered insights into the behavior of the light rays, suggesting that while the rays may be displaced, they remain parallel to their original direction. There is a recognition that the glass block does not function as a lens, which influences the convergence point of the rays.
The original poster's understanding is based on a drawing they created, which they feel does not support the idea of convergence on the screen. There is an ongoing exploration of the assumptions regarding the properties of the glass block and its effect on the light rays.
sweetgirl86
Two non-parallel light rays initially converge to a single point on a screen. A rectangular block of glass is now placed somewhere in front of the screen, in the path of the light rays, so that the glass surface is parallel to the screen. Where is the new convergence point of the rays?
1, Behind the screen.
2,On the screen (unchanged).
3, Inside the glass block.
4, Toward the glass block, in front of the screen.
I put inside the glass block, because i drew out the picture and i don't see the two rays converging at all because it is a glass block and not a concave lens. I drew a picture with the two rays entering then refracting towards the normal, and then refraction again when going out of the block, but this time away from the normal since its going from the glass to the air, and the speed of light in air is faster so the rays move away from the normal, which means that they don't converge on the screen at all. but that also means that they only converge at the initial point of contact which is when they first hit the block, but there is no option saying on the block, it just says inside the block. please help...
The light rays exiting the block will run parallel to the rays entering the block. The exit rays is offset to one side with respect to the entry rays. This happens because the refraction angle at the first interface (air -> glass) becomes the incident angle at the second interface (glass -> air) and we therefore get the same refraction angle in air (from Snell's law) at the second interface as when the beam entered the glass block. Usually one find such a diagram in a basic physics handbook.
You don't need a concave lens, you were told that the rays were already converging to a point on the screen. You are, in fact, right that the block does not act as any kind of lens and, so, does not change the convergence of the rays.
And so the rays stay on the screen (unchanged) ?
The rays are displaced off to one side, but they are still parallel to the original direction. Try drawing it.
Thanks for your help :-)
It's a pleasure.
11K
32K
