Proof that q^2 is divisible by rm^2
The discussion revolves around a mathematical proof concerning the divisibility of \( q^2 \) by \( rm^2 \), with participants exploring the implications of certain assumptions and the structure of the problem.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants are attempting to clarify the problem setup and the assumptions regarding \( n \) and \( m \). There is a suggestion to analyze the prime factorization of \( n \) and to consider the implications of \( p^2 = rm^2q^2 \) on the divisibility of \( q^2 \).
The discussion is active, with participants questioning the justification of certain assumptions and exploring different lines of reasoning. Some guidance has been offered regarding the structure of the proof and the relevance of prime factorization.
There are indications of missing information regarding the problem statement, as participants have requested clarification and details that are not fully provided in the thread.
courtrigrad
http://www.artofproblemsolving.com/Forum/weblog.php?w=564
Could someone help me with 2b?
Thanks
the link for me says
"You do not have the permission to view this blog"
I guess you have to register to see it?
Can you type the problem here?
you should be able to see it now. changed the settings
I'm getting a page that says it's your blog, but it also says "total entries: 0" and there's not much tehre besides a calendar.
Is it that long of a problem that you couldn't just type it in here?
yeah, now it should work.
Alright. You get to p^2=n*q^2 and then assume that n=2*t? That's completely unjustified.
If n is not a perfect square then you can write it as n=r*m^2 where r has the property that if s is a prime and s divides r then s^2 does not divide r, r>1 obviously as well (you should prove this). Proceed from p^2=n*q^2 and see what happens.
You could also just look at the prime factorization of n if you have unique factorization at this point.
Ok, so [tex]p^{2} = rm^{2}q^{2}[/tex] and [tex]p^{2}[/tex] is divisible by [tex]rm^{2}[/tex]. So then I have to show that [tex]q^{2}[/tex] is also divisible by [tex]rm^{2}[/tex]. Is [tex]m[/tex] just any positive number?
Thanks
Thanks
It's probably easiest at this point to focus on some prime that divides r, say s. Then it will look very much like the usual proof sqrt(2) is irrational.
However we have a little snag. You are looking at p^2=r*(mq)^2 and you don't necessarily have mq and p relatively prime, but you should be able to fix this without much trouble.
  • · Replies 26 ·
20K
  • · Replies 36 ·
9K
