Ventilation Systems: Calculating G & E Rates
The discussion focuses on understanding the concepts of generation (G) and evaporation (E) rates in ventilation systems. The user poses a question regarding the loss of 1 gallon of a chemical over a day, seeking clarification on whether this loss is categorized as G or E. It is concluded that evaporation refers to the loss of volume, while generation pertains to the gain of volume, potentially from condensation or other sources. The relationship between these two rates is expressed in the equation (V`-V) = G - x, where V is the initial volume, V` is the final volume, and x is the evaporation rate.
  • Understanding of basic fluid dynamics concepts
  • Familiarity with volume measurement and units of volume per time
  • Knowledge of equations relating to evaporation and generation rates
  • Basic principles of thermodynamics, particularly regarding phase changes
  • Research the principles of fluid dynamics in ventilation systems
  • Study the equations governing evaporation rates in various conditions
  • Explore the concept of condensation and its relation to generation rates
  • Learn about the impact of temperature and pressure on evaporation and generation
Engineers, environmental scientists, and HVAC professionals seeking to optimize ventilation systems and understand the dynamics of fluid behavior in chemical processes.
melpec
Hi...Prbably a stupid question but here it goes:
I have some equations here, some of them have a G for rate of generation and others have E for rate of evaporation (both of them have units of volume per time).
My question is: if I know that I have 3 galons of a chemical at the beginning of the day in one tank and at the end of the day I only have 2 galon...then I lost 1 galon per day...but is this number E or G? I mean...I don't understand what is the difference, I know there is an equation relating them but I don't understand the concept.
Is the problem that you don't understand the difference between Generation and Evaporation?
What is meant by generation in this context?
Evaporation is pretty self explanatory with regards to the description, however generation remains ambiguous with what you have described.
Generation sounds like it could possibly describe, among other things, the water condensation in a system.?
You have a variable volume, if you know the rate of evaporation and your final volume you can therefor calculate how much of the substance has entered the system ( possibly what generation is referring to here ).
Consider a sink of water. Water evaporates throughout the day, and you start with a known volume(V). At the end of the day you measure again the volume of water in the sink(V`).
From a formula for the rate evaporation (based on the conditions) you know that you loose x amount of water through evaporation during the day.
You know that the change in the volume of water is related to the amount of water lost and the amount of water gained through the day, where G is the amount gained.
(V`-V) = G - x
That is one possible interpretation of the meaning of Generation and G in this context. I am guessing though.
  • · Replies 30 ·
