Relative velocities in relativity
  • Context: Graduate
  • Thread starter Thread starter tfast
    Relative Relativity
The discussion revolves around the concept of relative velocities in the context of special relativity, particularly focusing on how observers in two spacecraft, traveling toward each other at significant fractions of the speed of light, perceive each other's velocities and the effects of relativistic phenomena such as time dilation and the addition of velocities.
  • Exploratory, Technical explanation, Conceptual clarification, Debate/contested
  • One participant questions their understanding of how observers on two spacecraft would perceive each other's approach velocities, particularly under different speed conditions relative to a reference object.
  • Another participant clarifies that the addition of velocities in relativity does not follow the classical rule (w = u + v) but instead uses the formula w = (u + v) / (1 + uv/c²), emphasizing the importance of this distinction in relativistic contexts.
  • A further contribution notes that as velocities approach the speed of light, the addition formula indicates that the resultant speed will never exceed the speed of light, reinforcing the relativistic limit.
  • There is mention of the Lorentz Transformations in relation to the velocity addition formula, although the context of its application is not fully explored.
Participants generally agree on the need to consider relativistic effects when discussing velocity addition, but there is no consensus on the specific implications for the scenarios presented, particularly regarding the perception of blue-shifting and the outcomes when velocities sum to or exceed the speed of light.
Limitations include the lack of detailed exploration into how different velocities affect the perception of light and potential variations in the scenarios where the spacecraft approach each other with differing speeds.
tfast
Hi--
I'm just trying to clean out some physics cobwebs in my head, as I was never much up on relativity; thanks in advance for accomodating me. Here's my question:
Imagine two spacecraft widely separated, but traveling toward each other at significant fractions of c (observed relative to the same reference object, say a sun). What would observers on each spacecraft see in the following situations:
a) each ship travels at v < 0.5c relative to the reference object
b) each ship travels at v = 0.5c relative to the reference object
c) each ship travels at v > 0.5c relative to the reference object
My naive assumption in the case of (a) would be that observers on either ship would see the other ship approaching at 2(v), with light from the other ship blue-shifted in proportion to that speed. However, this doesn't seem to take into account dilation effects, so I'm not really sure of this answer.
So, is the answer above correct, and furthermore, what happens when the ships' relative velocities sum to >= c in cases (b) and (c)? Finally, does anything change when the ships approach one another with velocities different from one other?
Thanks!
Originally posted by tfast
Hi--
Thanks!
Your right in that your answer doesn't take relativistic effect into account when adding the velocities. They do not add up by the rule
w = u+v but by
w = (u+v)/(1+uv/c²)
This is the correct formula for all additions of velocity. Note that when uv<<c (As in everyday experence), The formula gives an answer nearly identical with u+v, Which is why we still tend to use w = u+v for low velocity situations.
Just come extra notes ...
Note that as u->c and v->c the equation will reduce to :
w = u+v/(1+c2/c2)
w = u+v/2
so if u=~v
w =~ u =~ v
And this is why the speed of any object (relative to any other object) will never pass the speed of light.
Also note this equation is called "Lorentz Transformations"
Cheers all, thanks for the excellent answers!
  • · Replies 17 ·
  • · Replies 25 ·
  • · Replies 128 ·
  • · Replies 50 ·
  • · Replies 22 ·
