Do These Integrals Always Exist Under Certain Conditions?
  • Context: Graduate
  • Thread starter Thread starter lokofer
    Existence Integrals
The integrals discussed, specifically \(\int_{-\infty}^{\infty} dx \cos(uf(x))\) and \(\int_{-\infty}^{\infty} dxe^{-ag(x)}\), exist under the conditions where \(a > 0\) and \(g(x) > 0\) for all real \(x\). As \(a\) and \(u\) approach infinity, both integrals tend to zero. The discussion highlights the relationship between these integrals and the WKB approach in physics, particularly in defining the wave function \(\psi(x) = A \cos(S(x)/\hbar)\) in the semi-classical limit. The transformation of \(g(x)\) into its inverse \(h(x)\) illustrates the Laplace transform behavior, reinforcing the conclusion that the integrals converge to zero for large parameters.
  • Understanding of integral calculus, particularly improper integrals.
  • Familiarity with the WKB approximation in quantum mechanics.
  • Knowledge of Laplace transforms and their properties.
  • Basic concepts of real analysis, including limits and convergence.
  • Study the properties of improper integrals in detail.
  • Explore the WKB approximation and its applications in quantum mechanics.
  • Learn about Laplace transforms and their applications in solving differential equations.
  • Investigate the behavior of integrals under limits, focusing on convergence criteria.
Mathematicians, physicists, and students studying quantum mechanics or advanced calculus who seek to understand the convergence of integrals and their applications in physical theories.
lokofer
Let be the integrals:
[tex]\int_{-\infty}^{\infty}dx Cos(uf(x))[/tex] (or the same but a sine) and
[tex]\int_{-\infty}^{\infty}dxe^{-ag(x)}[/tex]
Where "a" is a a>0 positive constant, u can be either positive or negative.. and g(x)>0 for every real x.. my question is will these integrals "always2 exist under these conditions?..what would happen if we take the limit a-->oo and u-->oo ? are in this case equal to 0?
For the second case, set g(x)=1 (for all x). What do you see?
Oh..then sorry "Arildno".. then for similar case with f(x) and g(x) different from f(x)=C (C a real constant) and g(x)>0 i think the integrals should tend to 0 for big u and a, and that they exist..for example for the WKB approach in Physics if you definte the "Action" S of the system the approximate wave function can be written as [tex]\psi(x)= ACos(S(x)/\hbar)[/tex] so in the "Semi-classical " limit (h-->0 ) the Wave function is 0 , A is a normalization constant.
- for the case of real exponential if you take g(x)=h(x) so h(x) is the "inverse" of g(x) the function becomes a "Laplace transform" of h'(x) that tends to 0 for big a
  • · Replies 19 ·
  • · Replies 16 ·
  • · Replies 20 ·
