Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image brenouille Share It Thread Tools image
Old Apr18-03, 08:56 PM                  #1
SCSA
SCSA is
Posts: n/a
brenouille
Hi. Can somebody help me with Brenouille's equation. How is it theoretically derived and what are the effects. I have a project on that. Thank You.
Old Apr18-03, 09:45 PM                  #2
Stranger
Stranger is Offline:
Brenouille's equation says that the sum of the pressure (P), the kinetic energy per unit volume and the potential energy per unit volume, has teh same value at all points along a streamline.....
Consider a flow through a nonuniform pipe in a time [del]t....the force on the lower end of the fluid will be P,A, where P, is the pressure at the lower.....the work done at teh lower end by the fluid behind it is.......
W, = F,[del]x, = P,A,[del]x, = P,V
, - 1 like P1 = P,
; - 2 like P2 = P;
similarly...the work done on the fluid on the upper portion in time [del]t is....
W; = -P;A;[del]x; = -P;V
The assumtion is that the pipe is curved and that the force on the fluid at teh top is opposite to its displacement.....therefore the work done is negative......the net work done by these forces is....
W = P,V - P;V
Part of this work goes into changing the kinetic energy of the fluid and part goes into changing its gravitational potential......If m is the mass passing by the pipe in the time interval [del]t, then the change in kinetic energy of the volume of fluid is
[del]KE = 1/2mv;^2 - 1/2mv,^2
the change in potential energy is
[del]PE = mgy; - mgy,
We can apply the work-energy theorm ......W = [del]KE + [del]PE
P,V - P;V = 1/2mv;^2 - 1/2mv,^2 + mgy; - mgy,
density = mass/volume .... [rho] = m/V
P, - P; = 1/2[rho]v;^2 - 1/2[rho]v,^2 + [rho]gy; - [rho]gy,
P, + 1/2[rho]v^2 + pgy, = P; = 1/2[rho]v;^2 + [rho]gy;
P = 1/2[rho]v^2 + pgy = constant
Old Apr27-03, 12:06 PM                  #3
SCSA
SCSA is
Posts: n/a
Thanks stranger...
image image
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
