Calculating Magnetic Flux & EMF through a Conducting Loop
The discussion focuses on calculating magnetic flux and induced EMF in a square conducting loop positioned near a long straight wire carrying current I. The expression for magnetic flux through the loop is derived as Φ = (μ₀Ia/2π) * ln((s+a)/a). The user seeks clarification on the induced EMF when the loop is moved orthogonally and parallel to the wire, specifically noting that moving parallel does not change the magnetic field, resulting in no induced EMF. The conversation emphasizes the application of Ampere's Law in these calculations.
  • Ampere's Law
  • Magnetic Flux Calculation
  • Electromotive Force (EMF) Concepts
  • Understanding of Induction Principles
  • Study the derivation of magnetic fields using Ampere's Law
  • Learn about Faraday's Law of Induction
  • Explore the effects of loop movement on magnetic flux
  • Investigate applications of induced EMF in electrical circuits
Physics students, electrical engineers, and anyone interested in electromagnetism and the principles of magnetic flux and induced EMF.
student1938
A square conducting loop with sides a lies on a table a distance s from a very long straight wire carryinga current I.
a) Derive an expression for the magnetic flux through the loop.
b) Derive an expression for the EMF induced in the loop if it is pulled away in a direction orthogonal to the wire at speed v.
c) Derive an expression for hte EMF induced in the loop if it is pulled away in a direction parralel to the wire at speed v.
I know that I have to use Ampere' s Law to calculate the magnetic field but am not sure how to do this correctly and how will the field help to calculate the flux?
s is the distance between the the side of the square closest to the wire and the wire
I am able to calculate part a) now after having worked on it for a while...Phi = (mu0Ia/2Pi) * ln((s+a)/a)
c) According to me since s does not change there is no change in the magnetic field through the loop when the loop is moved parallel to the wire and so there should be no change in phi and so no dPhi/dt or no EMF...Is this explanation correct?
I need some major help with part b) please someone..I think that I have made a significant effort and now need just help with that part to solve the question...any feedback would be great.
Come on guys...something...pleeease!
