Register to reply
Stopping distance considering coefficient of friction
by Aubiefan
Tags: coefficient, distance, friction, stopping
Share this thread:
Aubiefan
#1
Sep17-06, 09:21 AM
P: 16
I am having a lot of trouble with this problem:
A car is traveling at 45.0 km/h on a flat highway. If the coefficient of friction between road and tires on a rainy day is 0.100, what is the minimum distance in which the car will stop?
I know it uses the delta X kinematics equation, so I should use friction to figure out the acceleration, but we haven't covered this material in class and I am at a loss for how to proceed. Also, will I be considering four systems, one for each tire in contact with the road?
Thanks, any tips are appreciated!
Phys.Org News Partner Science news on Phys.org
Flapping baby birds give clues to origin of flight
Prions can trigger 'stuck' wine fermentations, researchers find
Socially-assistive robots help kids with autism learn by providing personalized prompts
berkeman
#2
Sep17-06, 11:31 AM
Mentor
berkeman's Avatar
P: 41,059
What equation do you use to relate the frictional force F to the coefficient of friction mu and the normal force (weight) N? Even though N points down, which direction does the force F of friction point? And no, you don't need to do all 4 wheels, because you would just get 1/4 the force at each, which adds up to 1 for all of them. Show us your work and we can help guide you if you need help.
Aubiefan
#3
Sep17-06, 01:03 PM
P: 16
The frictional force (F) is mu times the normal force, but I don't know what the mass or weight of the car is, that iis one main thing that is confusing me. I am given the coefficient, so I have F= (0.1)n, which can be rearranged to 0.1=n/F, or 0.1=applied force/frictional force. So I know that frictional force is ten times the applied force, but I am still not sure what equation to use to try and get acceleration from that. Any tips on the best equation to use here?
Thanks for clearing up the issue about the four wheels, I appreciate it!
berkeman
#4
Sep17-06, 01:06 PM
Mentor
berkeman's Avatar
P: 41,059
Quote Quote by Aubiefan
Hint -- the mass of the car will cancel out of the equation. Set up the equation with the frictional force being the decelerating force. What is the equation of motion relating the force F, the mass m, and the acceleration a of an object?
Aubiefan
#5
Sep17-06, 03:08 PM
P: 16
I know that F=ma, so if F equals ma, so I would think that ma=0.1n, meaning acceleration is 0.1n/m. I also know that n=mg, so ma=0.1(mg), now I see where mass cancels out, thanks for the hint.
So I set a=(0.1)g, and got a=.98. I plugged that into V^2=Vo^2 + a(delta X), with 12.5 m/s^2 as Vo (my starting speed, converted from km/hr) and V=0. I solved for delta X, and got 76.56. When I typed it into my Webassign answer sheet, it told me it was incorrect but within 10% of the right answer. Any idea where I have gone wrong?
thanks for your patience!
berkeman
#6
Sep17-06, 03:17 PM
Mentor
berkeman's Avatar
P: 41,059
First, a typo -- the units of velocity are m/s. Second, the full equation for motion is
[tex]d = d_0 + v_0 t + \frac{a t^2}{2}[/tex]
[tex]v = v_0 + a t [/tex]
Use the 2nd equation to find the time it takes to stop, then plug that into the first one to get the distance. What answers do you get?
EDIT -- fixed a couple LaTex typos
Aubiefan
#7
Sep17-06, 10:21 PM
P: 16
I finally got it! I solved it using your method, and then tried the first method again and got the same answer, I guess I had been punching something into the calculator wrong. My final answer was 79.7 m.
Thank you so much for your help and your patience, it is EXTREMELY appreciated!!!
Register to reply
Related Discussions
Stopping distance General Physics 7
Stopping distance of a car Introductory Physics Homework 11
Stopping Distance Introductory Physics Homework 9
Stopping distance Introductory Physics Homework 8
Friction and stopping distance Introductory Physics Homework 5
