How Do You Calculate the Net Electrostatic Force in a Three-Point Charge System?
The problem involves calculating the net electrostatic force on a charge in a three-point charge system, specifically with charges located at defined positions on the x and y axes. The original poster presents a scenario with three charges and seeks to determine the magnitude and direction of the net force on one of the charges.
  • Exploratory, Problem interpretation, Assumption checking
  • The original poster attempts to calculate the forces between the charges using Coulomb's law and considers using trigonometry to resolve components. Some participants suggest using Pythagorean theorem to find resultant forces and question the calculations of distances and angles involved.
The discussion is ongoing, with participants exploring different methods to approach the problem. There is no explicit consensus yet, but some guidance has been offered regarding the use of Pythagorean theorem and the need to consider the correct forces acting on the charge in question.
Participants are navigating the complexities of the charge positions and the calculations involved, with some expressing uncertainty about their previous steps and the application of trigonometric functions.
duki
Problem:
A charge of +18 uC is on the y-axis at y = +3.0m. A charge of -12 uC is at the origin. Last, a charge of +45 uC is on the x-axis at x = +3.0m. Determine the magnitude and direction of the net electrostatic force on the charge at x = +3.0mm. Specify the direction relative to the -x axis.
So what I have drawn is:
O-> 18 x (10)^-6
| 3.0m
| Origin Charge: -12x10^-6
|O_ _ _ _ _ _ _ _ _ _ _ O -> 45 x (10)^-6
< 3.om >
So I did:
F1 = (8.99 x 10^9)(12 x 10^-6)(18 x 10^-6) / 9 = 1.942 N
F2 = (8.99 x 10^9)(12 x 10^-6)(45 x 10^-6) / 9 = 0.539 N
Can I use trig to determine the magnitude now? I tried it but I got this:
1.942cos90 = 0
1.942sin90 = 1
Surely I've messed up somewhere. Can someone point me in the right direction?
Thanks a bunch! :smile:
or would I do:
.539 cos 45
.539 sin 45
If you're finding the force on the charge at x=3m, you need 18x45 and -12x45 (with appropriate powers of 10, of course), and use pythagoras to find the distance between the 18uC and 45uC charges.
To find the magnitude, find the resultant force in the x and y directions, then use pythagoras.
Ok so I've done some of it right?
Then I do:
(3²)(3²) = 9² = 9??
i don't understand the second part
*bump*...
14K
  • · Replies 23 ·
10K
