Distance ball travels question
  • Thread starter Thread starter phantomcow2
    Ball
The problem involves determining the distance a ball travels when launched with an initial velocity of 34 m/s at an angle of 30 degrees. The context is two-dimensional motion, specifically focusing on projectile motion and the application of kinematic equations.
  • Participants discuss the need to split the initial velocity into horizontal and vertical components and explore the use of kinematic equations for each direction. There is a focus on understanding displacement versus distance and the implications of launching from ground level.
Participants are actively engaging with the problem, offering guidance and clarifying concepts. There is a productive exploration of how to approach the calculations, with some participants expressing readiness to attempt the problem collaboratively.
There is an acknowledgment of missing instructional background, as the teacher did not cover certain necessary concepts before assigning the problem. Participants are also questioning the assumptions regarding displacement and the initial conditions of the launch.
phantomcow2
I have a homework problem I was told to "think about". The teacher says he did not have time to teach us a few things we should know about this, but we should think about it over the weekend so we can do it on monday. Well I am trying, but I feel like there is information I am missing. Not information in the problem, but a method to solve.
A ball is given an initial velocity of 34m/s at an angle of 30degrees. Determine the distance the ball travels before it hits the ground.
Can somebody give some steps of how I would best solve this problem? We just started two dimensional motion, with your I and J vectors.
The information given is sufficient to solve the question. Do will need to split the initial velocity into two components, one vertical and one horizontal. Once you have done this you should use basic kinematics to produce two equations of motion (one for each component), once you have done this you should be able to solve the vertical component for the time of flight t and the horizontal component will then give you the distance travelled.
If you wish to attempt the question here, we will be happy to guide you through.
Okay so using trig, drawing a right triangle of vectors, I got a few velocities.
We know that the ball is thrown at 30 degrees, speed of 34m/s.
So Sine(30 * 34
17m/s as a velocity of our vertical.
29.45m/s as a velocity of our horizontal.
I would like to attempt it here if possible. THe equation I was thinking of was
Distance = Initial distance + Initial velocity * time + 1/2*a*t^2
But clearly that won't work because I have distance and time as a variable. So can you tell me what equation it is I would need to use? This may be one I have not yet encountered
Okay, let's look at each component independently. I am assuming here that the ball was launched from the ground and not an elevated position.
Vertically
As the ball is launched from the ground and returns to the ground, you know that the displacement is 0m, yes? You also know the initial velocity that you correctly calculated. You also know that there is a constant acceleration (due to gravity). So the equation you stated;
Is correct, but note that you should take the displacement and not the distance. Now you have only one known allowing you to solve for flight time.
Horizontally
Now, horizontally we have the initial velocity and we need to find the final displacement. Since there is no acceleration in the horizontal plane (ignoring air resistance) the ball will travel at a constant velocity, allowing use easily to calculate the distance travelled.
Do you follow?
You are correct to assume that the ball is launched from a ground position. So since there is no gravity in our horizontal, obviously our equation is simplified.
So you can use the displacement for the distance. But, do I know the displacement? Wouldn't I need to know the end point of where the ball would land and then use the distance formula to determine displacement?
Thanks for the help
Not if you just consider the vertical plane. In the vertical plane the ball started at ground level and it will obviously finish at ground level when it impacts. Since vertically it landed at the same level it started it's vertical displacement is zero. Do you follow?
Ah! That makes sense now.
So I can plug in 0 for my Distance for hte vertical equation. ANd now I have the perfect quadratic with a small bit of rearranging. I can solve for T.
NOw with T, I can plug this into my horizontal equation, correct?
Sounds spot on to me :smile:
  • · Replies 19 ·
