How big is a BLACK HOLE? Can it be calculated ?
  • Context: Undergrad
  • Thread starter Thread starter timejim
    Black hole Hole
The discussion centers on the size of black holes and whether it can be calculated. Participants explore the relationship between mass and size, the existence of various sizes of black holes, and the implications of general relativity on their characteristics.
  • Some participants propose that the size of a black hole is defined by its mass, with the Schwarzschild radius being a key factor.
  • Others argue that black holes can vary significantly in size, with examples given such as a black hole with the mass of the Sun having a diameter of about 6 kilometers.
  • A participant mentions that a black hole with the mass of Jupiter would have a diameter of approximately 5 to 6 meters, highlighting the extreme density required for black hole formation.
  • It is noted that in general relativity, Kerr black holes are a feasible type, characterized by a ring-shaped singularity and two event horizons.
  • Some participants discuss the theoretical possibility of creating small black holes in laboratories, referred to as optical black holes.
  • A participant provides a formula for calculating the radius of a black hole's event horizon based on its mass, emphasizing that the calculation is straightforward under certain assumptions.
  • Another participant mentions that there is no theoretical limit to the size of a black hole, as any amount of mass can form one if compressed to a high enough density.
  • It is stated that the Schwarzschild radius is directly proportional to mass, with specific examples given for black holes of varying masses, including a million-solar-mass black hole having a radius of 3 million kilometers.
Participants express a range of views on the size and calculation of black holes, with no consensus reached on the implications of their findings or the limits of black hole sizes.
Some calculations and assumptions regarding the mass and density of black holes are discussed, but the discussion does not resolve the complexities involved in these calculations or the definitions used.
timejim
How big is a BLACK HOLE? Can it be "calculated"?
I was curious as to whether or not the size of a Black Hole can be calculated. If known, can the size of black holes vary, I mean, are there small ones, large ones, etc.?
Astronomy news on Phys.org
The size of a black hole is defined by its mass. For a given mass, there is a length called the Schwarzschild radius, which is proportional to the mass. If the object in question is small enough to be inside this radius, it is a black hole. Anything crossing this boundary then becomes part of the black hole.
So the answer to the question is, they can be any size, but for a given size, the mass is huge. A black hole the size of a smll seed would have the mass of a mountain range (or so I am told by Charles Stross' sf novel Singularity Sky, and I have every reason to believe he did his homework) :=).
In general relativity, the most factible type of black hole is a Kerr black hole, that have a singularity with the shape of a ring.They have two, not one, event horizons
It has been proposed to create artificial little black holes here in laboratories in earth. These are called optical black holes
the size of a black holes varies all over the place
a black hole with the mass of the sun would have a 6 kilometer diameter
a black hole with the mass of the planet Jupiter would have a five to six meter diameter, I forget exactly
it is easy to calculate the radius if you know the mass, especially in the fairly ordinary case where you assume the hole is not electrically charged and not rotating. then it is an ordinary "
schwarzschild" which is to say "kosher" black hole and there is a real simple formula for the radius of the spherical event horizon which light doesn't escape from and which you must not touch
the size of the event horizon is what people ususally mean by the size of the hole
anyway here's the formula, you asked about calculating
Say M is the mass of the stuff that collapsed to make the hole, the mass of the hole itself in fact
And G is the famous Newton constant 6.674 E-11 cubic meter per sq. second per kilogram.
the radius of the event horizon (the dark ball that it is good to stay away from)
is 2GM divided by the square of the speed of light
[tex]\frac{2GM}{c^2}[/tex]
So take an example! Suppose M is 9 E27 kilograms
Then multiply by G and you get 6.674x9 E16 cubic meter per sq second.
And divide by square of speed of light which is 9 E 16 sq. m per sq. second
You get 6.674 meters so twice that is the radius of the hole
the hole is around 13 meters radius or 27 meters diameter.
Well you asked about calculating the size of the thing. It is not my fault if it comes out a bit dumb and clunky. Calculation has that aspect.
In principle there really is no limit on how big a black hole can get or have. Any amount of mass at all can in principle be made to form a black hole if you compress it to a high enough density. Logically though, however big the black hole is you can assume that is how big the massive star was. Also Astronomers suspect that many galaxies harbor extremely massive black holes at their centers, and some of these black holes are million times the more mass of our Sun, or or 10^{36} kilograms.
Ted Bunn:
The more massive a black hole is, the more space it takes up. In fact, the Schwarzschild radius (which means the radius of the horizon) and the mass are directly proportional to one another: if one black hole weighs ten times as much as another, its radius is ten times as large. A black hole with a mass equal to that of the Sun would have a radius of 3 kilometers. So a typical 10-solar-mass black hole would have a radius of 30 kilometers, and a million-solar-mass black hole at the center of a galaxy would have a radius of 3 million kilometers. Three million kilometers may sound like a lot, but it's actually not so big by astronomical standards. The Sun, for example, has a radius of about 700,000 kilometers, and so that supermassive black hole has a radius only about four times bigger than the Sun.
  • · Replies 20 ·
  • · Replies 40 ·
  • · Replies 17 ·
