Ring Theory: Equivalence Relations
The discussion revolves around the properties of equivalence relations in the context of ring theory, specifically examining whether certain relations, such as "is a subset of," qualify as equivalence relations. Participants explore the definitions and implications of reflexivity, symmetry, and transitivity in various examples and scenarios.
  • One participant suggests that the relation "is a subset of" could be an equivalence relation under certain conditions, but later acknowledges it fails to meet the necessary properties.
  • Another participant confirms that "is a subset of" is not an equivalence relation due to its lack of symmetry.
  • A participant questions whether relations that possess two properties of equivalence relations can be extended to a minimal relation that is an equivalence relation.
  • There is a discussion about creating an equivalence relation by fiat, using an example from module theory, where a relation is defined based on shared composition series.
  • Some participants express uncertainty about the implications of modifying definitions to create equivalence relations, with one arguing that such modifications change the original definitions significantly.
  • Another participant mentions that trivial relations exist that are equivalence relations, such as those where a~b is true for all a and b.
Participants generally agree that "is a subset of" is not an equivalence relation, but there is disagreement regarding the implications of modifying relations to create equivalence relations and the validity of certain examples presented.
Some discussions involve assumptions about the properties of relations that may not be universally applicable, and the exploration of examples may depend on specific definitions within the context of ring theory and module theory.
wubie
Hello,
I have a question regarding equivalence relations from my ring theory course.
Question:
Which of the following are equivalence relations?
e) "is a subset of" (note that this is not a proper subset) for the set of sets S = {A,B,C...}.
Example: A "is a subset of" B.
Now I know that for a binary relation to be an equivalence relation the relation must be symmetric, reflexive, and transitive.
I would initially say that e) would be an equivalence relation since the following:
e) This is not a proper subset so assume that each of the sets in S is a set equal to S. This should mean that the relation would be symmetric, reflexive, and transitive.
But since the possibility of the sets in S being proper subsets of S exist then the relation must have the following restriction: A R B and B R A (where R is the relation and A,B are elements of S) iff A = B. Would this mean R is anti-symmetric?
I would then guess that unless the relation is unconditionally reflexive, transitive, and symmetric then the relation could not be an equivalence relation. Would this be a correct assessment?
Any input is appreciated. Thankyou.
Right; this is not an equivalence relation.
Yes. Thankyou.
Actually I know that it is not an equivalence relation, but I was wondering if my reasoning was correct. I should have been more specific. Sorry.
Yes; because it fails to be symmetric, it cannot be an equivalence relation.
Thanks again Hurkyl.
does every relation having two properties of equivalence relations but not all three have a minimal relation that contains it as well as being an equivalence relation?
in particular, i know that if one adds the condition "or is equal to" to the relation "is a proper subset of", it becomes an equivalence relation equal to "is a subset of".
'Is a subset of' is not an equivalence relation for the same reason as 'is a proper subset of'
Here's an example of making an equivalence by fiat. (genuine maths)
Let S be the set of (finite dimensional) simple modules for a group algebra. define a relation on modules by M~N if there is some indecomposable module that has both M and N in its composition series. This is symmetric and reflexive, but not transitive. So just make it so by fiat. The equivalence classes are the blocks of the algebra.
oops. no, it's not symmetric, now is it.
sorry.
Unless I misunderstand what you're suggesting, the description you're giving is somewhat preposterous, since what it's really doing is defining ~ so that M~N if there is a path from M~N in a graph generated by assigning each module to a node, and placing edges between pairs of modules that share a composition series.
"So just make it by fiat" is actually a change to the definition of '~' which results from globbing the modules together.
I'm not sure what you mean. There is always the trivial relation: a~b is true for all a and b, and the other trival relation, a~b iff a = b. Obviously both are equivalance relations.
Consider that there are three properties:
Transitive, reflexive and symetric:
a~b iff a and b have a common factor > 1.
So transitive and symetric:
a~b iff a and b are both not 0.
Any transitive and symetric relation can be extended to an equivalance by adding that a~a if a=a.
transitive and reflexive:
a~b iff a ≤ b
It certainly isn't preposterous, and is one of the many equivalent definitions of blocks of algebras.
It's a standard, simple way to make a symmetric reflexive relation transitive.
Oh, perhaps you are not noticing the strong constraint that there is an *indecomposable* module with them as composition factors. You might perhaps need to know more about group algebras and projective modules, but this defintitely isn't 'globbing the modules together' merely some of them: those that lie in the same block; correspond to the same indecomposable idempotents of the identity functor; do something old fashioned with Brauer Characters.
  • · Replies 17 ·
